Stripboard Soundlab build
Page 1 of 1 [13 Posts]
LektroiD
PostPosted: Thu Mar 12, 2009 4:46 am    Post subject: Stripboard Soundlab build
Subject description: with step by step photos
This may be of use to the guys starting out; my build of the Soundlab in stages.
This thread is basically about the circuit build, and not so much about the front panel. Maybe someone will be kind enough to do a tutorial on panel making to compliment this thread.
First off, I used a 4mm drill bit (slightly wider than the copper tracks of the stripboard) and gave it a couple of light turns to cut the necessary tracks. It is absolutely essential to get this right, double check, and double check again before you cut! As you will see I made a mistake on my board, but this was rectified by bridging the erroneous cut with a short piece of wire (tweezers are very useful for small jobs like this)
It is always good practice to populate every circuit in stages, starting with the lowest profile components first, in this case the wire links. I always pre-bend the pins before mounting.
Next the horizontally mounted resistors. Notice they are all of the same orientation, makes it a lot easier should I need to troubleshoot later.
I then added the IC sockets and smaller capacitors, also I decided to use a female pin strip for connecting the panel components.
Continuing to add the components until the tallest components were in.
Next job was to wire the panel. I didn't have all the components to start with, but enough to be getting on with some of the wiring.
Once I got the required components, finished the panel wiring.
Added spaghetti.
A few more sockets and she's up and running:
Special thanks to Ray Wilson, Uncle Krunkus and everyone involved for making this project possible.
YouTube video coming soon...
My tunes available here
(check out the new Electro-Funk LP)
Audio files: 51
PostPosted: Thu Mar 12, 2009 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice job LektroiD! Very Happy
We would lose our friends.
So,.........
Audio files: 116
G2 patch files: 317
PostPosted: Thu Mar 12, 2009 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Or how a well structured path leads to success, good job indeed.
PostPosted: Thu Mar 12, 2009 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
very cool Smile
fwiw, I've got an exact replica upstairs of picture 2. It stopped there as this was the point when Ray's boards arrived. Now I also have a Ray board populated with resistors and erm.... not much else Embarassed Laughing
one day Tom. One day. Rolling Eyes
ACHTUNG!
Audio files: 116
G2 patch files: 317
PostPosted: Thu Mar 12, 2009 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
You could frame it for above the sofa I guess Laughing
LektroiD
PostPosted: Thu Mar 12, 2009 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I had a friend in the early '90s who had a broken TR606 on his wall.
Audio files: 107
PostPosted: Thu Mar 12, 2009 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
A very nice job and nice pictures. This will help someone who is doing a stripboard project for the first time. Thanks.
PostPosted: Thu Mar 12, 2009 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, I WILL finish it Twisted Evil
concentration has never been my forte Shocked
ACHTUNG!
PostPosted: Thu Mar 12, 2009 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
That'll be me then?? Rolling Eyes Laughing Laughing
ACHTUNG!
Audio files: 51
PostPosted: Thu Mar 12, 2009 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
If it's any consolation Tom, I think the level of concentration required to get a stripboard that size working perfectly is something which comes and goes. I doubt I'd have the chops to even begin one these days! Laughing
So,.........
LektroiD
PostPosted: Sun Apr 19, 2009 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.youtube.com/watch?v=TDFtp-7Uqcg
http://www.youtube.com/watch?v=UGSYKG2oVYs
LektroiD
PostPosted: Fri Sep 18, 2009 1:09 am    Post subject: Reply with quote  Mark this post and the followings unread
in its current state (click for larger photo):
Audio files: 69
PostPosted: Fri Sep 18, 2009 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
very good build, well laid out from start to finish, my friend built the strip layout WSG and made such a good job that i commandeered it to use in Epicyclus project Smile he he
www.myspace.com/skrogproductions
Niio2
