  Twyndyllyngs Live Chez Mosc
One-Line ChucK Crazy
Page 4 of 5 [121 Posts]
Inventor
Audio files: 267
PostPosted: Wed Sep 24, 2008 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, that worked, thanks kijjaz. Here is the test code to try out the drum set:
Code:
// Kijjaz's drum set
Impulse trigL => LPF toneL => SinOsc driveL => dac; toneL.set(50, 30); 1 => driveL.sync;
Impulse trigL2 => LPF toneL2 => SinOsc driveL2 => dac; toneL2.set(160, 30); 1 => driveL2.sync;
Impulse trigB => BPF toneB => SinOsc driveB => dac; toneB.set(2000, 100); 1 => driveB.sync;
Impulse trigH => HPF toneH => SinOsc driveH => dac; toneH.set(2000, 100); 1 => driveH.sync;
while (true) {
    50 => trigL.next;
    second => now;
    50 => trigL2.next;
    second => now;
    50 => trigB.next;
    second => now;
    50 => trigH.next;
    second => now;
Rinko
PostPosted: Wed Sep 24, 2008 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
hehe that's a wicked idea - tried to come up with a contribution to the kit. instead i got this. its not drum like at all but does start to sound like a merzbow track after a short while Wink
Code:
Impulse i => Noise n => SawOsc s => HPF f => dac; f.set (500, 200); s.sync ();
kijjaz
PostPosted: Wed Sep 24, 2008 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rinko: i tried to simplify your patch above. it should build the same sound.
Code:
Noise n => SawOsc s => HPF f => dac; f.set (500, 200); day => now;
i made some modification just for fun:
Code:
Noise n => SawOsc s => s => HPF f => dac; f.set (400, 300); day => now;
kijjaz
PostPosted: Wed Sep 24, 2008 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Code:
// still afraid of the dentist?
Step a => Phasor b => b => SinOsc c => b => dac; -200 => a.next; 250 => b.gain; day => now;
Inventor
Audio files: 267
PostPosted: Sat Mar 28, 2009 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just dug up this cool thread for my ChucK internet radio show. Gonna go through it and collect the best ones. Any suggestions? Any favorites?
kijjaz
PostPosted: Mon Apr 06, 2009 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Code:
//Crackling, no randomization!
Step s => dac; .5 => s.gain; float x; while(samp => now) Math.sin(x * 5.414369 + 1) => x => s.next;
Code:
// Crackling, more grounded.
Step s => dac; .5 => s.gain; float x; while((maybe*40+6)::samp => now) Math.sin(x * 5.414369 + 1.19972) => x => s.next;
Code:
// Crackling, sandy.
Step s => dac; .001 => s.gain; float x; while(samp => now) Math.tan(x * .09 + 1) => x => s.next;
sarigama
PostPosted: Tue Apr 07, 2009 6:57 am    Post subject: is there a way to play this one-line without any file
Subject description: | chuck or > chuck? something like that?
some supercollider users are now twitting one-line and others can copy it from twitter and paste it his editor ... and listen ...
will chuck user always have to create a file first?
if it's one line
maybe there's a way to avoid creating a file?
podcasting:
http://sarigama.namaste.jp/podcast/rss.xml
BobTheDog
PostPosted: Tue Apr 07, 2009 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome
Well I am not a chuck expert but you can do the same thing using Audicle.
PostPosted: Tue Apr 07, 2009 10:09 am    Post subject: Re: is there a way to play this one-line without any file
if it's one line
Welcome on board.
As the previous poster pointed out; we do have a editor with integrated VM that can run code from editor buffers.
Another option would be to type "chuck --shell" at your terminal. The idea of --shell is to be able to enter into a direct dialogue with the VM, this is still in a rather "alpha" stage but there you can enter simple code without the need for any external programs and indeed without a graphics server. I wouldn't recommend that as a very practical thing right now but you can if you really want to.
kijjaz
PostPosted: Tue Apr 07, 2009 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes.. running a ChucK code especially a one-line in command line is quite comfortable. Just like Kassen said, just go into ChucK shell, then on ChucK prompt, open with a { then just code the thing in, then close with } and enter. You'll hear it running.
Normally it'd be shred (thread) number 1. Use this command "- 1" to remove shred number 1 in case you want to stop the running program.
sarigama
PostPosted: Thu Apr 09, 2009 3:57 am    Post subject: yes
Subject description: just will report that
chuck %> {Noise a => BPF f => dac; for(1 => int x; x <360> now; }}
chuck %> [chuck](VM): sporking incoming shred: 1 (chuck_file.yodt1g)...
worked!! great! thax
i think i will dig this style
i once thought that this is good when you are doing things on x-less cui (vt) ..
but yes then .. no handy copy'n'paste
so most of the things has to be in your brain for sure ..
hmm .. maybe there's a way to | a line from vim to chuck --shell
directly from its editing mode .. ?
mean something like scvim ..
podcasting:
sarigama
PostPosted: Thu Apr 09, 2009 5:15 am    Post subject: yes
Subject description: reporting that
it worked on my intrepid
chuck %> [chuck](VM): sporking incoming shred: 1 (chuck_file.2hQP4S)...
^C[chuck]: cleaning up...
then there might be a way to | a line directly from vim's edit mode .. just like scvim?
podcasting:
kijjaz
PostPosted: Thu Apr 09, 2009 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm.. that'd be interesting, so you can make other program generate chuck code also. i never tried that before. Shocked
oh, by the way, i'd like to post some one-line codes on Twitter sometimes. what tag should I use? #chuck seems too common. how about #chucklang ?
if you all are on twitter, follow me at @kijjaz
kijjaz
PostPosted: Sun Apr 12, 2009 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is one is quite long.. too long actually,
but it sounds so nice for me i wanted to post it here.
Code:
// Digital Major Thingy
Step s => dac; float x; while(samp => now) { ((x * 7 + (now / 125::ms) $ int % 64) % 30000 => x) / 15000 - 1 => s.next; }
Code:
// Glistering Thingy
Step s => dac; float x; while(samp => now) { ((x * 99 + (now / 125::ms) $ int % 64) % 30000 => x) / 15000 - 1 => s.next; }
Code:
// Rotating Robotic Thingy
Step s => dac; float x; while(samp => now) { ((x * 501 + (now / 125::ms) $ int % 64) % 30000 => x) / 15000 - 1 => s.next; }
Code:
// Another Must-post Thingy
Step s => dac; int x; while(samp => now) { ((x * 49 + (now / 50::ms) $ int % 64) % 30000 => x) / 15000 - 1 => s.next; }
Chaotic Duo!
Code:
// Chaotic Duo!
Step s => dac; float x, y; while(samp => now) { (((x * pi => Math.cos) + y => y => Math.cos) + x => x) * y => s.next; }
Code:
// Visualizing the Chaotic Duo.
SinOsc s => dac; float x, y; while(samp => now) { (((x * pi => Math.cos) + y => y => Math.cos) + x => x) * y => s.freq; }
Another duo..
Code:
// Modulo together..
SinOsc s => dac; float x, y; while(20::ms => now) { (x * 19 + y) % 256 => x; (y * 7 + 1) % 64 => y; x * y => s.freq; }
cebec
G2 patch files: 31
PostPosted: Sun Apr 12, 2009 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Brutal kijjaz, I like it!
kijjaz
PostPosted: Mon Apr 13, 2009 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahhh!! Thanks a lot cebec.
I've got another chick to post tonight:
Code:
// Egg Factory
Step a => dac; int x; while(samp => now) (a.last() * 40000 / (x % 7500/1000 + 1) + x++) % 20000 / 10000 - 1 => a.next;
Code:
// Accidentally Hatched
Step a => dac; int x; while(samp => now) (a.last() * 8001 / (x % 3750/1000 + 1) + x++) % 20000 / 10000 - 1 => a.next;
Code:
// Phone Ring
Step a => dac; int x; while(samp => now) (a.last() * 80000 / (x % 3000/1000 + 1) + x++) % 20000 / 10000 - 1 => a.next;
Code:
// Egg Factory Error
Step a => dac; int x; while(samp => now) (a.last() * 80000 / (x % 11000/4000 + 1) + x++) % 20000 / 10000 - 1 => a.next;
Inventor
Audio files: 267
PostPosted: Mon Apr 13, 2009 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm going to play a few of these one-liners on The ChucK Show this Friday at 23:00 - 00:00 GMT.
cebec
G2 patch files: 31
PostPosted: Mon Apr 13, 2009 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I like these, too! Rhythmic, mechanical and harsh. Cool
http://www.soundcloud.com/cebec
Inventor
Audio files: 267
PostPosted: Sun May 24, 2009 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
At Jan's suggestion, we decided to make the theme of next week's ChucK Show be one-liners. I went through and tried basically all of them. Some didn't work because of html tags and some were too harsh sounding for my taste, however I did get 41 one liners to use in the show. That should pretty much do the job! Cheers!
Les
p.s. thanks for the thread kijjaz and all!
kijjaz
PostPosted: Sun May 31, 2009 5:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another of my favourite. Very simple, and cute.
Code:
// what a bird .. (successfully at sample rate = 44100)
SqrOsc s1 => Gain g => g => SinOsc s2 => g; s2 => dac; 20 => s1.freq; day => now;
Code:
// super 8-bit bouncing ball
SinOsc s1 => Gain g => g => SqrOsc s2 => g; s2 => dac; -.01 => s1.freq; day => now;
PostPosted: Tue Jul 14, 2009 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Not such a interesting sound but the technique is quite cool, I think, and stereo signals can be squeezed into 80 characters (barely).
Code:
Noise n=>dac.left;Noise m=>dac.right;int i;while(++i){0=>Std.srand;i*samp=>now;}
PostPosted: Tue Jul 14, 2009 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Purring waves.
Code:
SubNoise s=>dac;int n;while(++n%241+1=>s.rate){(n%83)*ms+ms=>now;5=>Std.srand;}
I like Std.srand()
Inventor
Audio files: 267
PostPosted: Tue Jul 14, 2009 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Kas, that one gets my vote for One-Liner-of-the-Year! Wow! It's like a Star Trek Phasor or something. Most excellent. Will appear on the next ChucK Show for sure.
PostPosted: Tue Jul 14, 2009 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm loving this one as well, and I really like this technique now. Do you get how it works? It's funny, I'm not spoiling the game while some people might still be trying to figure it out.
Edit; this is what that last one looked like before I cut it down to line-size. It's a bit more "musical". Warning; severe syntax abuse ahead....
Code:
SubNoise n => dac;
while(1)
    ((now/2::second)$int)%8 + 2 => n.rate;
    now%250::ms+ms=>now;
    5 => Std.srand;
Inventor
Audio files: 267
PostPosted: Tue Jul 14, 2009 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Now you're getting too crazy for me - I like the first one better. I don't get the technique, but let's let someone else figure it out, a little game shall we say? I mean, you posted your code openly so the secret is out yet I cannot fathom it. Well done Kas!
Les
