Physical output of CVs possible?
Page 1 of 1 [4 Posts]
puRe
PostPosted: Thu Oct 28, 2004 1:58 pm    Post subject: Physical output of CVs possible? Reply with quote  Mark this post and the followings unread
I've been wondering is it possible to patch (well, it is possible to patch it, but does it work) the (for example) sequencer gate and pitch signals to 2 outputs and then connect them to an analog synth...I know this is possible with Creamware sound card in conjunction with Creamware Modular III software...
PostPosted: Thu Oct 28, 2004 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
What you are actually looking for is a midi to CV interface?
http://home.earthlink.net/~wavefront/midi.html
http://m.bareille.free.fr/mcv876/mcv876.html
http://www.philrees.co.uk/products/miditocv.htm
http://musicmoz.org/Instruments/Electronic/Synthesizer/Links/MIDI_to_CV_Converters/
And this is just a small selection of what is out there..
Flickr
ian-s
Audio files: 42
G2 patch files: 584
PostPosted: Thu Oct 28, 2004 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's a nice idea, I think you will find the AC coupled outputs will not work the way you want. If you are into hardware, with a couple of dollars worth of IC's you could make a demultiplexer. Then you could use the virtual multiplexer and vco (for a clock) to rout 8, 16 or whatever cv's using only two of the G2 outputs. If I still had an analogue modular, that's what I would do. Or maybe an 'of the shelf' midi-cv would be better? Then you could still use output 2 and 3 for audio.
puRe
PostPosted: Fri Oct 29, 2004 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, I am aware of them...the thing was just an idea I got/stole from the Creamware guys who made it work with some mods...
Niio1
