CEM3396
Page 1 of 1 [2 Posts]
Somatic Circuits
PostPosted: Sun Mar 01, 2009 7:36 pm    Post subject:  CEM3396
Subject description: CEM3396 Designs / Experiences
Hello! Anybody with experiences with the CEM3396?
I am planning a build with it driven with a vc clock , to use it as a vc synth core. Idea Has anyone done this Question
moylando
PostPosted: Wed May 13, 2009 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
One problem using it outside of a microprocessor controlled environment is that the waveform is not a constant shape for a given waveform when the timing pulses change frequency. The waveform CV needs to change along with the timing frequency. Check the datasheet for more details.
You could in theory build an analog circuit to map a CV that might go to your master oscillator to modify the waveform CV.
If you want to know what it sounds like check out the Oberheim Matrix 6 and Matrix 1000. They used these chips.
Niio2
