G2 windows 7 and USB drivers
Page 1 of 1 [14 Posts]
jack
PostPosted: Tue Apr 20, 2010 6:08 am    Post subject: G2 windows 7 and USB drivers
Subject description: USB drivers for windows 7
I just upgrades to Windows 7 and can't get the USB drivers installed.
Anyone have a fix?
JACK
ark
G2 patch files: 31
PostPosted: Wed Apr 21, 2010 8:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
What happens when you try? What OS version are you running on your G2?
jack
PostPosted: Fri Apr 23, 2010 9:59 am    Post subject: G2 USB Drivers /Windows 7 Reply with quote  Mark this post and the followings unread
I loaded the new editor (1.62) with no problems. The USB drivers loaded fine on an older computer running XP but I still can not get them to install on Windows 7.
JACK
ark
G2 patch files: 31
PostPosted: Fri Apr 23, 2010 10:32 am    Post subject: Re: G2 USB Drivers /Windows 7 Reply with quote  Mark this post and the followings unread
What version of the G2 OS are you running? That is, what number appears in the G2 LCD when you turn it on?
What version of the USB drivers are you trying to install?
What happens when you try to install the USB drivers? Are you running on an account with administrative privileges?
jack
PostPosted: Sat Apr 24, 2010 2:11 pm    Post subject: G2 USB Window 7Drivers Reply with quote  Mark this post and the followings unread
My G2X is running OS 1.62 EXP.
The drivers I'm trying to install are the USB v2.15 64 bit.
When I try to install the drivers I get - Windows ws unable to install your Nord Modular G2X. If you know the manufacture vist the site and check for support.
Thanks for your help
JACK
ark
G2 patch files: 31
PostPosted: Sat Apr 24, 2010 2:18 pm    Post subject: Re: G2 USB Window 7Drivers Reply with quote  Mark this post and the followings unread
To my knowledge there is no 2.15 driver. There is a 2.16 driver.
I haven't used Windows 7, but isn't there a way of installing a driver in XP or Vista compatibility mode? I don't think Nord officially supports Windows 7 yet, but I seem to recall that other people have successfully used their drivers with Windows 7.
Oli
PostPosted: Tue May 04, 2010 10:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have just installed my G2 USB drivers and editor in Windows 7 64 bit, then updated to OS 1.62, and everything seems to be working fine.
However, when I first connected my G2X to the my PC's USB port, Windows attempted to automatically locate a suitable driver. This fails, and gives an error such as mentioned here.
I went into the Device Manager, found the faulty G2 device, and manually installed the v2.16 x64 driver. Clavia actually include a document describing how to manually install the driver (covers XP and Vista, but Win 7 is very similar to Vista anyway). I think if you install the editor, you should have a link to this in the Start menu. I have attached it here anyway.
Let us know how you go with this.
Oli
edit - Somehow I am not able to attach the document here. I get a message that I have reached the limit of a 20MB upload quota. I don't think that can be correct. Anyway, I think the guide is installed with the editor (at a guess) and for me, can be found at:
"C:\Program Files (x86)\Clavia\Nord Modular G2 v1.62\Clavia USB Driver Installation.pdf"
Good good study, day day up!
Audio files: 116
G2 patch files: 317
PostPosted: Wed May 05, 2010 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like that was correct (a couple of G2 SW versions adding up to about 20 MB), I upped your quota.
Oli
PostPosted: Fri May 07, 2010 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, I completely forgot about that. hehe. I knew I hadn't done any patches or audio worth uploading, and it would have taken a fair bit of those to breach quota, anyway.
Cheers Jan.
Oli
USB driver installation guide
 Filename:  Clavia USB Driver Installation.pdf
 Filesize:  665.93 KB
 Downloaded:  443 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Fri May 07, 2010 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome Oli ... and oh ... before I forget things too Laughing in the chat Howard said that Jack had solved his problem ... it was said that he had been trying to install 64 bit drivers on a 32 bit OS. Well anyway, it's good he got it working.
Audio files: 107
PostPosted: Fri May 07, 2010 9:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I spent some time with Jack trying to sort out his problem. As Blue said, it turned out that he was trying to install a 64 bit driver on a 32 bit OS. He's now running fine on Windows 7. Thanks all for the help and suggestions.
jack
PostPosted: Mon May 10, 2010 5:45 am    Post subject: G2 windows 7 USB drivers Reply with quote  Mark this post and the followings unread
Howard helped me with the driver problem. The main problem was I was trying to install 64 bit drivers instead of the 32 bit. Thanks for all the help.
JACK
drumfish
PostPosted: Wed Aug 10, 2011 7:04 am    Post subject: FRENCH USER clavia 64bits usb driver update failed
Subject description: following the instructions from the pdf of clavia ... nothing
windows 7 64 bits, nord modular g2 exp os 1.62, clavia 64 bits usb driver
my drivers keeps crashing, i follow the procedure from the pdf of clavia but still the problem remains. i plug the usb, it shows the clavia 64 bits usb driver needed to be updated, i double click, update it & then it shows this :
http://drumfish.deviantart.com/#/d462q9r sorry guys it's in french
something like : "cannot verify the signature of this driver ... might be a corrupt file"
thanks to help me out ... my mac is dead so i had to find a cheap pc quickly ... i'd forgot the pleasure of windows ...
Audio files: 107
PostPosted: Tue Aug 16, 2011 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Drumfish: I don't know what your problem can be, but at least with Vista, you can get the system to ignore the signature file stuff. Here is a link to a topic that explains how to do this for Vista. It may work, or not, with Windows 7.
http://electro-music.com/forum/topic-27903.html
mps board
