Polyphony X 2
Page 1 of 1 [8 Posts]
Moody33
G2 patch files: 16
PostPosted: Tue Nov 02, 2010 4:39 am    Post subject: Polyphony X 2
Subject description: ...or how to get more than 32 voices in a patch.
This patch show you how to multiply polyphony by 2 within simples patches. In this example you can get 48 voices if you set max voice to 24.
POlyX2.pch2
 Filename:  POlyX2.pch2
 Filesize:  1.27 KB
 Downloaded:  2244 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Nov 03, 2010 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I love tricks like these. Smile
PostPosted: Wed Nov 03, 2010 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is neat, yup!
iPassenger
G2 patch files: 78
PostPosted: Thu Nov 04, 2010 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cunning. Smile
iP (Ross)
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue Sep 13, 2011 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
can you explain your patch more specificly?
i've been developing unison voice related patches for a couple years
also used these in commercial tracks.
but when i play this patch it is just panning left and right
depending on the amount of voices selected.
what i would be looking for is , press 1 key, and feel the power of 32 with just 1 osc. and still be able to play polyfonic. and with your so called voice doubler i should be able to use 48 voices when 24 is selected?
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Tue Sep 13, 2011 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
i've recorded some audio to explain why i'm asking about this.
1st you hear your patch in my nmg2x, then after you hear the unison sound i made.
cheerss
NMG2 - PolyX2 _ ChronoUnison.mp3
PolyX compare ChronoUnison
 Filename:  NMG2 - PolyX2 _ ChronoUnison.mp3
 Filesize:  582.74 KB
 Downloaded:  992 Time(s)
Moody33
G2 patch files: 16
PostPosted: Wed Sep 14, 2011 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Panning in my patch is only to hear what the patch do.
If you want more voices for one key , you can use the status module ( see clavia help) with my patch to get a polyphonic unison. But you have to switch off all Keyboard tracking ( env and osc) and set them with the keyboard module.
I haven't got the time to explain more.
Good luck.
Chrono
Audio files: 37
G2 patch files: 38
PostPosted: Wed Sep 14, 2011 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
im not unfamiliour with that, ill give it a try Smile thanks for your time
