negativspace
Joined: Dec 25, 2010 Posts: 15 Location: Manhattan, Kansas
Posted: Tue May 10, 2011 3:45 pm Post subject:
Arp 4072 VCF Bleedthrough Fix Subject description: Clarification of instructions needed! |
Yves,
I built one of these for a fellow over on Muffwiggler's and we're trying to fix the bleedthrough issue. He forwarded me some instructions you gave him, quoted here:
"The cure is to replace the resonance potentiometer by a dual gang model. Connecting the CW lugs in parallel, the CCW lugs in parallel, and one wiper lug connected to the normal resonance circuit while the other wiper lug connected to the R43 resistor."
I am unclear on one thing - when you say 'connect to R43' do you mean in place of R43, or to its input leg, or to its output leg? Thank you! |
dstrength
Joined: May 23, 2010 Posts: 15 Location: Mobile, Alabama, USA
Posted: Sat May 21, 2011 12:48 pm Post subject:
| I think you're just replacing the T-connection on the schematic..so looking at the schematic, remove the T and tie the left side of R43 to the other wiper. |
yusynth
Posted: Sat May 21, 2011 11:58 pm Post subject:
Ok I am back home.
I mean "connect to" not "replace", this means unsolder the left leg of R43, solder a wire this leg and connect this wire to the wiper lug of the second potentiometer of the dual-gang pot. _________________ Yves |
negativspace
Posted: Sun May 22, 2011 1:46 am Post subject:
Perfect. Thanks for the clarification! Thanks to dstrength for the help too. I'm out of town on business right now but I will assemble the module next week and report back.  |
negativspace
Posted: Sun May 29, 2011 10:57 pm Post subject:
This seems to do the trick. It absolutely kills the bleedthrough and seems to leave the low end intact at high resonance. The resonance control response is altered slightly - self-osc seems to come in differently - but it's neither more- or less-usable... just different. It still sings beautifully in self-oscillation and tracks my entire 5-octave keyboard.
Thanks again. |
yusynth
Posted: Sun May 29, 2011 11:17 pm Post subject:
| negativspace wrote: | This seems to do the trick. It absolutely kills the bleedthrough and seems to leave the low end intact at high resonance. The resonance control response is altered slightly - self-osc seems to come in differently - but it's neither more- or less-usable... just different. It still sings beautifully in self-oscillation and tracks my entire 5-octave keyboard.
Thanks again. |
Fine then, I will add a note at my site. _________________ Yves |
Sebo
yusynth
Posted: Sat Jun 25, 2011 12:05 am Post subject:
Thanks for the feedback !
I will publish this mod then  _________________ Yves |
djfill
Joined: Jan 10, 2012 Posts: 23 Location: Cardiff, Wales, UK
Posted: Wed Feb 08, 2012 5:54 am Post subject:
Hi Guys...
I think I have the 'Bleedthrough' issue and just wanted to confim the symptoms with someone before I try this fix.
When I set the frequency to 0 and increase the reasonance, i can still hear the waveform slightly. Is this bleedthrough? (The answer seems obvious when i put it like this but I just want clarification before i start making a mess of my board.)
Thanks. |
yusynth
Posted: Wed Feb 08, 2012 6:14 am Post subject:
| djfill wrote: | Hi Guys...
Thanks. |
You answered yourself
Yves _________________ Yves |
djfill
Posted: Wed Feb 08, 2012 6:44 am Post subject:
| yusynth wrote: | | djfill wrote: | Hi Guys...
Thanks. |
Yves |
I thought so...thanks Yves! (congrats on the new synth btw...looks great!) |
