dnigrin
Posted: Fri Dec 31, 2010 6:05 am Post subject:
Thanks Dave for the purchase - post some audio and/or video of how you end up using it! _________________ Dan Nigrin - Defective Records
CycliC, M185 & Klee Sequencers / MC-202, MC-4 & DSX Hacks / Audio Plugin & General MIDI Players
http://defectiverecords.com |
DES
Posted: Fri Dec 31, 2010 2:44 pm Post subject:
klangumsetzer wrote: | hello dave,
maybe you can share your experience here. i too use thesys and wonder if and how the klee can compliment thesys.
best regards
eike
Initially the fact that Klee is able to do two sequences at once (well, possibly three if I understand the other mode...) as well as how it's programming is approached would affect how how i composed with it. Thesys is pretty straight ahead programming - although it is VERY powerful! I absolutely love it! In fact on my NYE stream tonight I'll have three different sequences ready to go using Thesys. I know I can run multiple instances of it. so the fact that Klee can run the two isn't a big issue...it's more it's approach I think. And for $40? Not a bad buy. I've got to get my download link from Dan yet for the Klee - so I don't know if I'll be using it tonight or not. If you don't catch the stream I'll have it recorded and post it here in the radio section.
BTW - Sugar-Bytes just realeased version 1.5 of Thesys today. Besides being 64 bit you can export sequences and it has a stand alone mode. _________________ Dave
www.davesneed.com |
DES
Posted: Fri Dec 31, 2010 2:47 pm Post subject:
dnigrin wrote: | Thanks Dave for the purchase - post some audio and/or video of how you end up using it! |
Not a problem Dan!
Can you check the address though that you sent the download link to? Still haven't received it..... PM me if you have any questions - or use the email address you emailed me at before. _________________ Dave
www.davesneed.com |
klangumsetzer
Posted: Mon Jan 03, 2011 3:36 am Post subject:
hi dave,
thanks for the info. the klee soft might be the first gear purchase of the year...
best regards
eike
soundklinik
Posted: Sat Jan 08, 2011 4:26 am Post subject:
Subject description: request 4 busses and MIDI channels? |
Hello Dan,
is it possible that you implement saving 'busses' and midi channels in presets? At least temporarily, while you're playing?
I was making (and storing) some patches in Klee, using Reaktor 5:
In R-5, I had 3 synths opened each with a different MIDI channel, (1-3) and using LoopBe1, (everything works perfect).
I saved some patterns in presets while switching midi channels in busses, basically a variation of the same pattern played with a different synth. Then I started switching between saved presets, expecting to hear what I saved, but no, it only played last midi/buss preset...
And please, the "last setup" memorized?
cheers |
dnigrin
Posted: Sat Jan 08, 2011 7:24 am Post subject:
soundklinik wrote: | is it possible that you implement saving 'busses' and midi channels in presets? |
I originally had it this way when I was developing v2 of the app, but what I found was that when switching presets that included a change in the bus device (especially when that change involved VST instruments), it would make for a discontinuity in the outputted sound, as it takes some time for the app to load the new VST. To avoid that, i removed the ability to store the bus device. Perhaps what I could do in a future revision is to make it optional whether presets store the bus device or not, and then let the user decide one way or the other...
soundklinik wrote: | And please, the "last setup" memorized? |
I will see if I can do this as well.
Thanks for the feedback! _________________ Dan Nigrin - Defective Records
soundklinik
Posted: Sat Jan 08, 2011 10:11 am Post subject:
Dan said:
Quote: | ...it would make for a discontinuity in the outputted sound, as it takes some time for the app to load the new VST. |
New VST?...
I didn't know that VST has to be (re) 'loaded' again...
In Reaktor, the (VSTs) are there, (the 3 that I choose), all I want to do, is to change the midi channel path...so synth 'W' listens to channel 1, and before it listened to ch. 3, that was synth 'M'...
In Reaktor, you have the 'luxury' to load several instruments and give them each a different (or shared) midi channel, so only CPU is the limit....
Just to clarify, I don't want to change VST, or programs/sounds, (that would be nice, but I know i can't, as you say in manual), only midi channel... (the pattern with notes etc. is already saved in Klee's memory, and the question is which synth from the 3 available will play them notes)...
Also I found that using "Standalone Reaktor", or Battery3 (or any standalone) is much better then (the same) VST version.
For example, VST-Battery3 was flashing 20-40% CPU in Battery, standalone 1-2%
And with my midi keyboards that sends clock, I can 'splice in' a drum machine....heaven ...but that's off subject, n'est pas?
But, the last memory on start up would be really great,.... I have to load : in Setup-1)midi device, BCR2000, 2) the text for it
Main page: 1) Midi controller PCR-2, 2)Midi clock-PCR-1,... 3) external midi/audio (don't use that much)...or am I being lazy? |
dnigrin
Posted: Sat Jan 08, 2011 2:01 pm Post subject:
OK, I understand. For you, since you would only be changing the MIDI channel in the output busses, you wouldn't experience any of the discontinuity I was talking about. That case is when users are loading up their VST's *within* the Klee software (unlike in your example, where you are loading them up in Reaktor).
I will try to make it an option in a future update, as to whether presets store the state of the Busses or not.
And you're not being lazy - I know what you mean, and I'll try to have it "remember" between sessions for the next version! _________________ Dan Nigrin - Defective Records
soundklinik
Posted: Sat Jan 08, 2011 4:44 pm Post subject:
Quote: | Dan said:..since you would only be changing the MIDI channel in the output busses, you wouldn't experience any of the discontinuity I was talking about. That case is when users are loading up their VST's *within* the Klee software... |
I don't know of any software that can load a VST with a patch on the next beat .... however it would be nice if Klee could temporarily store patch changes (same vst while in session)... that would be great ...
thanx for your support and help, cheers |
DES
Posted: Thu Apr 28, 2011 8:38 am Post subject:
Klee Version 2.1 out now! |
Version 2.1 released...
Downloaded it last night Dan. Looking forward to trying it out later tonight! _________________ Dave
www.davesneed.com |
dnigrin
Posted: Thu Apr 28, 2011 9:07 am Post subject:
Hey, you beat me to the punch!
Yes, version 2.1 now available - not a huge number of changes, mostly bug fixes, but one important change is how the Load button works. I got a lot of feedback about having the Loads only happen on quarter note clock ticks, rather than the very next clock tick. This should help keep things "in time" a bit better hopefully... _________________ Dan Nigrin - Defective Records
drumcodeuk
Posted: Mon Dec 12, 2011 1:46 am Post subject:
Hey,
Just wanted to say I bought the software Klee a few days ago and have found it to be a really useful and interesting sequencer.. I really like it and have got some good results from it already.
Saw the post on the Spectralis forum but have just been using it with a Yamaha FB-01 and a DSI Mopho so far.
Are you still working on it or do you consider it done now?
I don't think glide is implemented yet which would be good and as well as notes sending out midi CC's could lead to some pretty complex and unusual patterns I think. Anyway, great as it is.
Nick. |
dnigrin
Posted: Mon Dec 12, 2011 5:16 pm Post subject:
drumcodeuk wrote: | Are you still working on it or do you consider it done now?
Nick. |
Thanks for the nice words about the software - Scott Stites is the one who deserves the real praise though!
I do still hope to implement some new features over time - both of your suggestions are already on the list! That said, I'm working on a few other projects at the moment, so not sure what the timeline will be for when I will get to these for the Klee.... _________________ Dan Nigrin - Defective Records
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Fri Dec 16, 2011 4:53 pm Post subject:
MusicMan11712 wrote: | Thanks for the prompt reply. One suggestion for the demo version, can you give people a week or so to try it (with the ability to save)? I was going to try using it for an experimental performance but the 20 minute limit and inability to save what I was working on really made it hard to (1) give it a fair test drive and (2) play my results for others to hear.
--Steve |
I read recent comments about the software Klee and wondered if you reconsidered the 20 minute/no save limit. However, based on another post, it looks like you are quite happy with this restriction.
Needless to say, I am disappointed. Oh well. |
dnigrin
Posted: Fri Dec 16, 2011 7:02 pm Post subject:
Afraid to say that I don't have plans to change the copy protection - sorry! _________________ Dan Nigrin - Defective Records
Posted: Sat Dec 17, 2011 11:05 am Post subject:
dnigrin wrote: | Afraid to say that I don't have plans to change the copy protection - sorry! |
Oh. Maybe you misunderstood me. I wasn't commenting on copy protection; my comment was on the 20 minute limit for the trial version. Sorry if I wasn't clear about that. |
dnigrin
Posted: Sat Dec 17, 2011 4:32 pm Post subject:
I'll consider bumping the time up for the next update. _________________ Dan Nigrin - Defective Records
klangumsetzer
Posted: Thu Jan 05, 2012 5:23 am Post subject:
klangumsetzer wrote: | (...) thanks for the info. the klee soft might be the first gear purchase of the year...
well the m185 and klee software apps were the first and only gear purchases in 2011... _________________ Make a joyful noise!
Eike |
DES
Posted: Thu Jan 05, 2012 9:30 am Post subject:
I need to get back to my sw Klee. Last time I tried using it, it complained about how many vsts I had .... Time to thin the heard again _________________ Dave
www.davesneed.com |
DES
Posted: Wed Jan 18, 2012 12:49 pm Post subject:
Version 2.1.2 now available
Thanks Dan for keeping up with this. _________________ Dave
www.davesneed.com |
dnigrin
Posted: Wed Jan 18, 2012 12:53 pm Post subject:
Very welcome!! _________________ Dan Nigrin - Defective Records
Loopy C
Joined: Aug 08, 2009 Posts: 3 Location: Valyermo, CA, USA
Posted: Sat Jun 02, 2012 7:53 pm Post subject:
To celebrate the recent purchase of M185 and CycliC, I spent the evening re-visiting 'Klee'.
Truly a surprising sequencer, really enjoying the possibilities in terms of avant garde textures.
http://loopyc.com/?p=2715
Here, three tracks of Klee were used, each track using 'external' MIDI CC to vary the 'pots' and 'Range' in realtime.
Thanks again Dan for providing these wonderfully esoteric options. it's what I live for I can't wait to incorporate these ideas into more developed tracks (my above 'blog' is strictly for 'work in progress' experimentations as they happen).
"Shut up, he explained"
Chris R Gibson ( a.k.a. Loopy C )
www.micworks.com
http://www.loopyc.com
http://www.jesusworedickies.com/Inspector_19/JWD.html |
dnigrin
Posted: Wed Aug 15, 2012 7:33 am Post subject:
Cool stuff Chris, thanks for posting!! _________________ Dan Nigrin - Defective Records
dalekay
Joined: Nov 16, 2003 Posts: 145 Location: Lancaster CA
Posted: Sun Dec 02, 2012 10:47 pm Post subject:
Is it me or the web sites are down?
Dale |
dnigrin
Posted: Mon Dec 03, 2012 8:15 am Post subject:
You mean the Software Klee site? Working fine here... _________________ Dan Nigrin - Defective Records
