Pattern Rotator
Page 1 of 1 [5 Posts]
Spandex
PostPosted: Wed Dec 22, 2010 5:22 pm    Post subject: Pattern Rotator
Subject description: A patch to rotate note sequencer patterns
Don't know if this is of any use to anyone else.. it's a VERY simple patch Smile
But I found that I'd often build a loop using the G2, and I'd be hearing it with the downbeat in a particular spot that wasn't in sync with the MIDI clock.
When it came time to sync up something else, I'd often end up manually changing the sequencer to rotate all the values to the new bar start.
With this patch, I just copy the note sequencer I want to rotate.. open this patch, paste parameters into the left sequencer.. select a rotation value in 16ths (from 1 to Cool and enable it. It just records it into the sequencer on the right, through a shift register. Then I can copy/pasteparams back to my original patch. Very simple.. saves me lots of time.
Oh, i've found no easy way to rotate the event/gate switches.. but they're much easier. I imagined building a patch using MIDI messages to do this .... but it'd be quite complex and I find it easier to just fix it manually.
PatternRotator.pch2
 Filename:  PatternRotator.pch2
 Filesize:  1.67 KB
 Downloaded:  2139 Time(s)
Lovely Cloakroom.... Lovely Cloaks
Sinuosity
G2 patch files: 11
PostPosted: Fri Apr 22, 2011 4:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I prefer use lfo instead sequencer. And there is no need to build complex patch for midi control. just use phase //Sorry my bad english Confused
Rotator.pch2
 Filename:  Rotator.pch2
 Filesize:  1.18 KB
 Downloaded:  4493 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Fri Apr 22, 2011 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
^^^Brilliant!! Smile Thanks
iP (Ross)
grimley
G2 patch files: 9
PostPosted: Mon Aug 15, 2011 5:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sinuosity ... brilliant indeed! I never would have thought of that. Cheers!
Sleep Distillery
Apeirophobe
Sinuosity
G2 patch files: 11
PostPosted: Tue Jun 12, 2012 12:06 am    Post subject: Reply with quote  Mark this post and the followings unread
another variation of Sequencer StartPoint Shifter.
SeqStartShift.pch2
 Filename:  SeqStartShift.pch2
 Filesize:  2.03 KB
 Downloaded:  4219 Time(s)
