adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Thu Jan 06, 2011 6:52 am Post subject:
Your lucky yourself chap. Could have been more than a few opamps that would have been fried. Cricklewood were selling them bout 6 months ago for £3.50. i kid you not. i think they realised after i ordered 20. They had the intersil CA3280G and RCA CA3280H.  |
sonicwarrior
Joined: Dec 22, 2005 Posts: 189 Location: Cologne, Germany
Posted: Mon Jun 20, 2011 5:43 am Post subject:
Today I finally started to assemble my Neural Agonizer:
Would you recommend to use the driver and recovery highpass filters or to left them out? (R84, R103, C43, C52, C56) |
sonicwarrior
Posted: Tue Jun 21, 2011 6:48 am Post subject:
Damn, today I found out that I didn't buy the phone jacks and that Mouser doesn't sell them anymore.
Is there an alternative for the Kobiconn 161-3525?
Mouser only has a 161-3525L-E which according to the datasheet is totally different and won't fit the PCB.
Edit: Looks like the 161-352N-EX will do. It is mono and fits according to the datasheet. |
/mr
Joined: Aug 05, 2007 Posts: 223 Location: Elektron City, Sweden
Posted: Fri Jul 22, 2011 4:44 am Post subject:
I'm also intrigued by the optional components here...
I'm building a Tellun Neural Agonizer right now. A number of possible modifications are mentioned in the documentation, namely variations of some of the R and C values of different filters, etc. I've left most of these resistors/capacitors unmounted so far.
Are there any of these modifications that might be useful to have selectable via switches on the front panel, or should I just go for the default values? Or - as a compromise - mount sockets on the PCB, letting me put in different component values to try them out? What would you recommend?  |
NoizeToyz
Posted: Thu Nov 15, 2012 9:27 am Post subject:
Calibration |
Hi All,
I've happily stuffed my NA boards, and am now at the stage of going through the calibration stage. I've tried the steps explained in the PDF build document, however I seem to be getting unexpected readings on my 'scope.
I measure the square wave from my MOTM300 and it looks like a square wave on the scope (all good!) but when I test at the points mentioned in the build document and adjust the trimmers; they don't seem to have any effect. The document suggests that I should be seeing some signal in both pos and neg, but all I get is a flatline that is so far below the zero that I have to adjust the voltage sensitivity on the scope to see it.
It's probably due to me not setting the scope up properly...
I've built quite a few modules now, but only just got my 'scope which is a 20mHz analogue beast sat on my bench. I'm a bit of a noob using scopes so need a few tips on using it in the calibration stage of the TLN-156 build.
Cheers! |
NoizeToyz
Posted: Thu Nov 15, 2012 10:12 am Post subject:
TLN-156 Neural Agonizer Panel Layout MU |
Hey,
Here's my 5u Moog panel layout - thought I'd share it, and maybe get some feedback. Feel free to use as you need it. I've put the Hi-Res PDF, the original Illustrator CS3 file, and a JPEG.
Ben over at Re:Synthesis has made some beautifully finished panels for me > http://www.bigbluewave.co.uk/resynthesis/resynthesis_home.htm
| Description: |
| Filesize: |
59.65 KB |
| Viewed: |
73 Time(s) |
| Description: |
| Original Adobe Illustrator CS3 doc |
 Download |
| Filename: |
MU 3u TLN-156.ai |
| Filesize: |
3.74 MB |
| Downloaded: |
70 Time(s) |
| Description: |
| Hi_Res PDF print-ready version |
 Download |
| Filename: |
MU 3u TLN-156 copy.pdf |
| Filesize: |
3.39 MB |
| Downloaded: |
70 Time(s) |
sduck
Posted: Thu Nov 15, 2012 11:07 am Post subject:
| Very nice! After using mine for a few years I'd suggest grouping the feedback and LPF knobs together, and put the deform knob up on top - switching the deform and feedback knobs. The feedback and LPF knobs kind of work together. No ideas on your electrical issues - does the thing work otherwise? |
NoizeToyz
Posted: Fri Nov 16, 2012 8:43 am Post subject:
Thanks sduck - that's some good advice; I haven't finished building it yet so had to guess which knobs would be the most important for twiddling!
Think I haven't finished building it yet so gonna put it together this weekend and see how it sounds - can't wait to hear the springy drones! |
