2013 Build Pictures
Page 1 of 4 [90 Posts]
Goto page: 1, 2, 3, 4 Next
PostPosted: Sat Jan 05, 2013 3:08 pm    Post subject: 2013 Build Pictures
Subject description: Show us what you built!
I finished my 2nd prototype of a Thomas Henry 555-VCO tonight (had to do a few corrections using new unfamiliar solder, so the PCB looks a little bit worn out):
TH_555-VCO new by fonitronik, on Flickr
fonitronik at
EdisonRex
Audio files: 168
PostPosted: Sat Jan 05, 2013 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful, Mattias.
It doesn't look that bad at all. Smile
Garret: It's so retro.
roglok
PostPosted: Sun Jan 06, 2013 6:15 am    Post subject: Re: 2013 Build Pictures
Nice! So the PCB won't accept DIP transistor pairs? Only hand-matched and metal can?
PostPosted: Sun Jan 06, 2013 6:34 am    Post subject: Re: 2013 Build Pictures
it is made for hand-matched 2N3906. fortunately ian fritz shared a nice and simple method/circuit with us to do this job...
fonitronik at
Boogdish
PostPosted: Fri Jan 11, 2013 3:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've finished three modules this week! Some of the PCB stuffing on these was done in 2012, so maybe that's cheating, but I'm still happy.
On the left is two bandpass filters and a mixer. Center is a new project of my own design. And on the right is EFM 3522 which I'm really happy with.
PostPosted: Fri Jan 11, 2013 10:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
First completed module of the new year, though I did most of the soldering last year....
Pay no attention to the weirdness with the label Smile
 Filesize:  868.62 KB
 Viewed:  25 Time(s)
mrkva
PostPosted: Sun Jan 13, 2013 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
3x nicolases saw vco + mix
PostPosted: Mon Jan 14, 2013 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
finished the hexinverter.net seqSQUARED last night:
fonitronik at
diablojoy
PostPosted: Sat Feb 02, 2013 12:22 am    Post subject: Reply with quote  Mark this post and the followings unread
nice one matthias
I am all over the shop lately with builds but i actually managed to complete this one in the last week.
A boogdish voltage to rhythm convertor
quite fun it is too !
 Filesize:  504.93 KB
 Viewed:  24 Time(s)
ask where the hell am I
as good an answer as any
Heavy Metal Kid
PostPosted: Sat Feb 02, 2013 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Made a couple of LM386 amps and housed them in honey cans. The one on the left has a bumped speaker and sounds noticably crappier than the other one. Smile
Audio files: 254
PostPosted: Sat Feb 02, 2013 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
nice speakers! flower
here's my latest finished project, which started out with
Tim Escobedo's PWM circuit and as usual I added some more things to it.
I will probably post some more details later in another thread.
but here are the pics Cool
 Filesize:  100.15 KB
 Viewed:  36 Time(s)
 Filesize:  66.62 KB
 Viewed:  17 Time(s)
 Filesize:  85.87 KB
 Viewed:  23 Time(s)
http://www.acidtrash.com/
Audio files: 69
PostPosted: Sat Feb 02, 2013 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
excellent colours Smile almost matches the fleece pattern in the background.
Great build phobos.
www.myspace.com/skrogproductions
Bogus Noise
PostPosted: Tue Feb 05, 2013 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Meant to post this at the end of last year, but... well... things got a bit hectic! I know it looks rough, but as I'm starting out I wanted a usable modular more than I wanted to spend ages on panels, building a proper case etc. Also no particularly esoteric modules just yet, figured it'd be best to get all the basics going first Smile
It's mounted in a flatmate's old CD shelving unit (almost Euro size already), using panels made from a nasty kind of plastic I found loads of offcuts of next to a bin outside a furniture shop. I'll break the bank another day.
Modules are:
1 x Basic 4011 clock for the sequencer
1 x Dual Channel 4017 CV/Gate/Trigger Sequencer, with built in glide and crossfade between the two CV channels
3 x Thomas Henry VCA
4 x Ray's Cool New LFO (skipped the sine output for now)
1 x Dual Slew (just left over from prototyping the sequencer)
1 x MFOS Soundlab MiniSynth Plus VCF
1 x Transistor Noise
1 x Dual AR Gen
...aaaaaand a crappy 555 osc for a testing sound source. A proper osc is pretty high up the priority list!
Mostly built on stripboard as well, aside from a Ray Wilson bipolar power supply.
Actually, there's another cool project from 2012 I didn't get to post yet, but I need to finish the video first! Should be doing plenty this year too though Smile
Circuit Bent Sonic Absurdity:
www.bogus-noise.co.uk
http://www.youtube.com/user/BogusNoise
zthee
PostPosted: Mon Feb 11, 2013 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I built a TKB -
isak
Audio files: 9
PostPosted: Mon Feb 11, 2013 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Not finished yet, need to check why the LP dose not sounds good with valvucaster overdrive, unlike the BP and HP, that sounds amazing.
MFOS - SVF
MFOS - LFO
MFOS - AR
MFOS - Audio to gate
MFOS - Noise
Bugbrand - Crusher
Valvucaster 12AU7 overdrive.
Draal
PostPosted: Mon Feb 11, 2013 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm working on a small machine based on some of my favorite lunetta chips. He's called V'Ger and is a portable racket maker as opposed to it's bigger patchable brother.
The chips:
1 x 40106 (made 4 oscillators in this set up)
1 x 4512 8 input data selector
1 x 4040 Divider
1 x 4046 built as a pitch tracker based on Nic Collins' design)
Three slow oscillators are the ABC controllers of the 4512. The C controler also has a switch to choose between the slow clock or the output of pin 2 of the pitch tracker.
Another clock with a HI/Lo switch goes to the 4040 to set the octaves that the 4512 will "play".
The 4046 has a Hi/Lo cap switch as well to offer some unique sounds.
I am still thinking about my enclosure; I have a few tins around here so I'll see where that takes me. Here's a crappy video of the device Smile :
Zontar Prevails!
Heavy Metal Kid
PostPosted: Mon Feb 11, 2013 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
zthee wrote:
I built a TKB -
That looks fantastic, zthee!
What kind of front plate is that? And how did you apply the text/graphics?
zthee
PostPosted: Mon Feb 11, 2013 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
It's aluminium, I used a German company that drills and lasers engraves the panels.
Heavy Metal Kid
PostPosted: Mon Feb 11, 2013 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! What company is it, btw?
dougseidel
PostPosted: Tue Feb 12, 2013 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
draal:
I love that - looks like it will be a fun instrument. the low-end sounds are great.
http://dougseidel/tumblr.com
PostPosted: Tue Feb 12, 2013 10:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
basic 40106 clock (thanks to diablojoy for pointing out the one-shot solution to make it a trigger clock without double triggering like I was when I tried to use a comparator), plus a couple stages of YuSynth clock divider, plus the "super simple S&H" circuit from kickstarter a while back....
Originally was going to be VC Noise + the S&H but I couldn't get it to fit into 1U so that went back onto a different spot on my backlog.
playing around with the S&H and the clock dividers:
https://soundcloud.com/elmegil/sample-and-thump
 Filesize:  2.16 MB
 Viewed:  17 Time(s)
PostPosted: Wed Feb 13, 2013 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
i got a very cheap fake PELI case from an electronics remnants online store and decided to make a portable system from it:
fonitronik at
bubzy
Audio files: 47
PostPosted: Wed Feb 13, 2013 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik stop!
your stuff is painfully neat Smile
nice work
_Richard_ Smile
Scot Solida
PostPosted: Thu Feb 14, 2013 4:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I moved house a few months ago and have yet to set up my screen printing gear. However, I wanted to convert a Red Llama distortion clone into module form for convenience so decided to hand-paint the thing. My inner-teenager came to the fore, bringing with it all those years of drawing Tolkien and D & D pictures back in the early 1980s. Silly, but adds some color to the black metal facade.
It sounds like this:
http://www.theelectronicgarden.com/Scot/LittleFuzzy.mp3
mcop
PostPosted: Thu Feb 14, 2013 11:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks great. Have been thinking of building a version of the Craig Anderton Tube Sound Fuzz (which the Red Llama is apparent based on) for my system and your sound clips have convinced me.
Niio1
