Wanting short tones from 40106
Page 1 of 1 [5 Posts]
astroman
PostPosted: Thu Apr 11, 2013 11:14 am    Post subject: Wanting short tones from 40106 Reply with quote  Mark this post and the followings unread
Finished Lunetta #1 and hope to put a demo vid up soon. For my next one I want to be able to make short percussion type notes. How is this acheived as opposed to a drone?
Audio files: 574
PostPosted: Thu Apr 11, 2013 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
there are a lot of ways this can be achieved but a simple one that comes to mind is triggering the V+ pin of a 40106.
an example could be a switch to V+ (or an external source) followed by a potentiometer in series attached to pin14, and a
capacitor to GND (probably something in the range of 100nF to 100uF). Different values will cause different attack/decay times.
vactrols instead of the pitch pot or maybe in series with the V+ pin can also create nice short bursts.
SoundCloud BandCamp Stickney Synthyards Captain Collider
astroman
PostPosted: Fri Apr 12, 2013 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks man! I reckon with my limited knowledge I can pul his one off! I certainly get the idea of that!
JingleJoe
PostPosted: Mon Apr 15, 2013 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/topic-54483.html
corex
PostPosted: Mon Apr 15, 2013 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could also gate your signal with an AND/NAND gate. If your signal is S and your gate G, then when G is high, G AND S will output S (meanwhile, G NAND S will output (NOT S) when G is low). With a short gate, you will get a short tone.
