Found a bunch of 4013 chips
Page 1 of 1 [7 Posts]
astroman
PostPosted: Fri Jul 05, 2013 6:59 am    Post subject: Found a bunch of 4013 chips Reply with quote  Mark this post and the followings unread
What can I do with them?
corex
PostPosted: Fri Jul 05, 2013 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is an extremely simplistic example, but I used the 4013 to create latching pushbuttons in a module I called "manual gate".
Schematic
 Filesize:  9.78 KB
 Viewed:  486 Time(s)
astroman
PostPosted: Sat Jul 06, 2013 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Corex........Thanks for the reply but I don't understand what that does? Embarassed
corex
PostPosted: Sat Jul 06, 2013 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
The module has four momentary switches, so it outputs a gate when you press (and hold) a momentary switch. I use the flipflops to hold state so that instead when you press a momentary switch, the output signal simply toggles (from on to off or vice versa) and then holds that state until you press the momentary switch again to toggle it.
The trick is to run \Q back to D, and use the momentary switch as the clock -- when the user presses the momentary, they clock the next bit in to the latch. In this mode it is essentially working as a divide-by-two clock divider.
https://en.wikipedia.org/wiki/D_flip_flop#Gated_D_latch
astroman
PostPosted: Sat Jul 06, 2013 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Corex for that explaination!
trav
PostPosted: Wed Jul 17, 2013 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is also not a bad chip brought more or less straight out to the panel. Experiment with different clock speeds into the CLK and DATA pins, maybe throw something at SET or/and RESET too, and listen to one of the outputs.
If you really have a lot of them you could build your own shift register, flip-flop by flip-flop, as long as you like! (connect output of one flip-flop into data of next) or combine with a proper shift reg chip to get the right number of bits/taps for a maximal linear feedback shift register...
Likewise, you could build your own binary counter out of a bunch of these: connecting NOT-Q to DATA (like Corex' example) gives a square wave at Q which has half the frequency of the signal at CLK (use this to clock the next flip-flop for division by 4, then 8, and so on...)
This chip isn't amazing, but playing with it is a good way to see how flip flops work, and so how other chips which are basically combinations of flipflop logic work too
astroman
PostPosted: Wed Jul 17, 2013 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Trav! Hoping to try some of this in a few days!
