  Muied Lumens Frequencies
The LFX experimental LFO (8K LFO and Weird Waveshapers)
Page 2 of 3 [62 Posts]
marvkaye
PostPosted: Fri Aug 26, 2011 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great ideas, Tim. I've suffixed the LFX with an "r1" and added it and the date to the silkscreen. I've already placed a MiniBoard Pro order for these, should see them on Monday. I'll put up photos as soon I get one populated.
If you'd be so kind to post the LED driver addition I'll bet it could be added to the existing board without growing its size. Personally, I don't have a problem adding a little daughterboard (if necessary) to add functionality.
<marv>
bubzy
Audio files: 63
PostPosted: Sat Aug 27, 2011 12:08 am    Post subject: Reply with quote  Mark this post and the followings unread
added the text and transistor to my layout, have etched the board just now, gotta wait for my wife to wake up before i drill it though :p results later .........
bubzy
Audio files: 63
PostPosted: Sat Aug 27, 2011 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
working Smile pcb layout confirmed :p
marvkaye
PostPosted: Sat Aug 27, 2011 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool, congratulations and well done. Care to share your update with the LED driver??
PostPosted: Sat Aug 27, 2011 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
tokyomatik wrote:
i already went to that web site but i use a mac, i didn't found a version for osx Sad
It's worth getting Fusion or Parallels for this. I know it's a pain, but it's a little price to pay for progress. Swings and roundabouts really. Because you have the Mac, you save on no having to buy all that stupid extra software to keep the damn PC in check. Just update everything initially, do a clone, and trash the bugger when it goes wrong, replacing it with a clone of the clone later!
Great LFO Tim!
ACHTUNG!
Dougster
PostPosted: Sat Aug 27, 2011 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
/me posts obligatory complaint about software not being available under Linux...
(Which is why I use Eagle...)
Once you start down the modular path, forever will it dominate your destiny!
Every DIY person should own a copy of Electronotes: http://electronotes.netfirms.com
Blue LEDs are evil.
Tim Servo
PostPosted: Sun Aug 28, 2011 12:35 pm    Post subject: The LFX experimental LFO (8K LFO and Weird Waveshapers)
Subject description: R 02 schematic with new R5 value
Hey Everyone,
One small change to note. R5 should be 220 Ohms, not 470 Ohms as I originally listed. I've updated the schematic on the first page, so that is correct now. With R5 at 470 Ohms, you'll only get a range of 4,200:1, but with R5 at 220 Ohms, you'll get the full range (about 8,800:1). Sorry for the error, and thanks again to Ian Fritz for letting me know. If you've already installed R5 and don't want to pull it out, you could just install another 470 Ohm resistor in parallel. The resulting resistance will be roughly 230 Ohms, which is definitely close enough.
Tim (one small change) Servo
marvkaye
PostPosted: Mon Aug 29, 2011 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I received my MiniBoard Pro order from ExpressPCB today... can't say enough nice things about them. Here's a picture of the component side of one of their boards complete with solder mask, component screens, the works. Were I to cut the boards in half, the laid in cost from them for this level of service came to about $14/module including shipping. I didn't make any allowances on the boards for mounting so will probably use Thomas Henry's method of glued angles (courtesy of his "Build a synth" DVD, thank you TH!) BTW, the price could have been around $10 per module by ordering the PCBs without solder masks or screens. It's a great deal either way if you ask me.
<marv>
Nice stuff from ExpressPCB
 Filesize:  157.66 KB
 Viewed:  235 Time(s)
Tim Servo
PostPosted: Mon Aug 29, 2011 7:08 pm    Post subject: The LFX experimental LFO (8K LFO and Weird Waveshapers) Reply with quote  Mark this post and the followings unread
Hey Marv,
Looks nice! A couple of thoughts on PCBs (these are just some things I do on my own / Magic Smoke PCBs)
1) Include the board name, and a date or revision number so you know what the board is and what schemo you used for it.
2) On the part designators (R1, U3, etc.), I always try to move them off to one side so that they're still visible when the part is in place. Makes troubleshooting or modding quicker and easier. You can't always do this on really cramped boards, but one most of mine I've been able to do it.
3) If possible, try to keep all similar parts pointing in the same direction. In other words, all ICs should point the same direction. I also try to keep all resistors in the same orientation. It generally makes assembly easier and makes the board look cleaner. This is a must for boards that are going to be automated, although that's something I've never had to worry about (although I do have a project coming up ...)
4) Whenever possible, traces on one side of the board should be at a right angle to traces on the other side. This minimizes interference, and even though that's not going to be a problem on an LFO board, it is a good habbit to get into.
For layout software, I've had really good luck with KiCAD (and it's free / open source).
Let us know how the LFX boards work out!
Tim (has plenty of bad habbits too) Servo
marvkaye
PostPosted: Mon Aug 29, 2011 7:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
HI Tim,
Thanks for all the great pointers. If I ever manage to actually come up with my own PCB design I'll try to keep them in mind. It was actually bubzy who did all the heavy lifting with this one, I just made a few very minor changes and sent ExpressPCB money Rolling Eyes
I'll probably cut small stencils for them and airbrush the name of the board and revision down the center... I figured I'd keep them together and layout a MOTM style front panel that accommodates the pair.
Did you ever come up with the LED driver for this? MFOS Ray has a simple one that takes a couple resistors and a 2n3904 (on his Synth DIY page under the "Hot tips" menu item) but I don't know if it's appropriate to this application or even where it would tie into the circuit. Just curious....
<marv>
Tim Servo
PostPosted: Mon Aug 29, 2011 10:07 pm    Post subject: The LFX experimental LFO (8K LFO and Weird Waveshapers) Reply with quote  Mark this post and the followings unread
Hi Marv,
For marking the boards, you might want to also consider a fine-tip permanent marker, or even a paint marker (don't know if those come in a fine tip).
As far as an LED driver, the transistor driver on Ray's site is an excellent, and very simple solution. I have some slight enhancements on that, but that original design is the simplest. You can hook it up to any of the waveform outputs - the buffer will pull very little current from the output, so the output can still drive lots of mod inputs.
Tim (the original, and the simplest) Servo
bubzy
Audio files: 63
PostPosted: Mon Aug 29, 2011 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry its been such a while, been very busy. marv, the transistor driver is quite simple. try this https://homepages.westminster.org.uk/electronics/images/vot3.gif
in the meantime, ive added it to the circuit board and done a little shuffling of components to try and fit a shrouded header onto the power pins. something i overlooked in the original design.
***this now includes the pdfs of the indiviual layers***
LFX PCBv2.zip
 Filename:  LFX PCBv2.zip
 Filesize:  40.67 KB
 Downloaded:  345 Time(s)
marvkaye
PostPosted: Tue Aug 30, 2011 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Life beyond e-m.com?.?.? Whoda thunk it? Wink
Not a problem. The LED schematic you shared is very similar to the one on MFOS... I'll do the math for the LEDs I'm planning on using and modify the circuit accordingly. Thanks for sharing it.
Can't wait to open up your new zipfile, anxious to see your LED implentation... no time now, but later. Life beyond e-m.com, doncha know?? Laughing
<marv>
Tim Servo
PostPosted: Tue Sep 06, 2011 5:24 pm    Post subject: The LFX experimental LFO (8K LFO and Weird Waveshapers) Reply with quote  Mark this post and the followings unread
Hi All,
I just posted a handul of different LED driver circuits at
http://www.electro-music.com/forum/topic-49449.html
I'll post more as I have time, but there are a few there to get you started. I use the "Bipolar Driver with Adjustable Bias" for the output of my LFX and it really works nicely. Smile
Tim (head towards the blinky light) Servo
oculus
PostPosted: Mon Jul 22, 2013 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Congrats and thanks for sharing this Tim
this LFO sounds very interesting,
i´ll definetly try this one out.
this would be amazing with a retrigger option,
to be able to kind of sync it to the tempo of the song one would be working on.
do you think this could be possible by using a fet transistor ? or some other way?
Tim Servo
PostPosted: Tue Jul 23, 2013 5:27 pm    Post subject: The LFX experimental LFO (8K LFO and Weird Waveshapers) Reply with quote  Mark this post and the followings unread
Hi Oc,
Yes, it's pretty easy to set up sync on this (or most other) LFOs by using an FET or an analog switch to change the charge on the timing cap. You can set up the circuit to pull the cap up to V+ or down to V-. In most triangle core oscillators, the integrator is inverting, so this means that pulling the timing cap up to V+ means the output triangle will be reset to V-. By the same token, pulling the cap down to V- means that the output wave will reset to its positive peak. It just depends on what behavior you prefer (or you could even put in a switch). The circuit below has already been posted on the Magic Smoke Facebook page (that's the place to go if you want to see this stuff a little sooner).
Tim (peaky!) Servo
Sync Circuit for the Magic Smoke 8K LFO - works with most other LFOs too.
 Filesize:  671.91 KB
 Viewed:  392 Time(s)
feggster
PostPosted: Wed Jul 24, 2013 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
hi, looking at the pcb..where do the pots connect? do they use the same numbering as the schematic?
oculus
PostPosted: Wed Jul 24, 2013 8:18 am    Post subject: Re: The LFX experimental LFO (8K LFO and Weird Waveshapers) Reply with quote  Mark this post and the followings unread
Tim Servo wrote:
Hi Oc,
Tim (peaky!) Servo
Nice thank you so much, can´t wait getting back home from the countryside to try this circuit out.
diablojoy
PostPosted: Wed Jul 24, 2013 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tim is there a reason for not pulling the intergrator cap to 0V ?
instead of the negative or positive rail
resetting the wave to 0V seems more intuitive to me
ask where the hell am I
as good an answer as any
Tim Servo
PostPosted: Wed Jul 24, 2013 10:29 pm    Post subject: The LFX experimental LFO (8K LFO and Weird Waveshapers)
Subject description: A question of resets...
Hey DJ,
In this design, you can reset the cap to 0V by connecting the 6.8K resistor to 0V. However, if you pull the cap to 0V, the output won't consistently reset. If the LFO wave was on the down slope, a reset to 0V will make the output start at 0V and head negative. On the other hand, if the LFO wave was on an upward slope, the reset will set the output to 0 and the it will start up. Resetting the LFO wave to the negative (or positive) peak means that the output behaves exactly the same way on every reset, regardless of where the LFO wave was when the sync pulse hits.
Tim (resetting it to 0K?) Servo
bubzy
Audio files: 63
PostPosted: Thu Jul 25, 2013 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
yep
_Richard_ Smile
feggster
PostPosted: Thu Jul 25, 2013 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
bubzy wrote:
yep
thanks, another great schematic and pcb to add to my to do list Smile
diablojoy
PostPosted: Thu Jul 25, 2013 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Tim
makes perfect sense.
I seem to remember seeing something along similar lines on the time machine schematic using a DG chip for resetting the LFO /EG to a known point and forcing a particular direction, would have to look it up again though to be sure.
bubzy
Audio files: 63
PostPosted: Fri Jul 26, 2013 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
haven't made a pcb for some time, so this might not work, I haven't tested it (or done a huge amount of error checking :p)
this is the original board, but with the sync section added.
hope it works, let me know if it doesn't and ill fix it.
lfxsync.zip
 Filename:  lfxsync.zip
 Filesize:  46.12 KB
 Downloaded:  203 Time(s)
_Richard_ Smile
isak
PostPosted: Thu Sep 26, 2013 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim and Guys.
just wanted to make sure that the scheme that open this post is the last updated scheme of the 8k LFO, i'm asking cause i seen few schemes of the 8k in the forum
Isak E.
