  Various Artists Live streaming concert in memory of Antimon
VC sine/cosine generator revisited
Page 3 of 4 [76 Posts]
frijitz
Audio files: 54
PostPosted: Wed Jan 07, 2009 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, the caps are good. Next guess is that the difference comes from differences in OTA gm. You could try making the feedback trimmable, as in the full 6/8 phase unit and as in Henry's design. The balance between neg and pos feedback is quite delicate. When working properly the system takes several hundred cycles to start up.
So you could try making the 10k a trimmer and take the bottom of the 820k off the slider. You might also need to change the values of the 820k and 4.7M resistors. For example, replace the 4.7M with 1M and the 820k with 100k.
OTA offsets also make a difference in how the system works. Your OTA may just have more offset than the ones I was working with. In fact, I probably used units selected for low offset vs gain variation.
I don't know of anyone trying Henry's design. Rene has a tri core TZ VCO at his site:
http://www.uni-bonn.de/~uzs159/index.html
I'm working on a SAW core unit right now.
Ian
UofMEShop
PostPosted: Wed Jan 07, 2009 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
UofMEShop wrote:
Can you comment on this LM13700 quadrature sine/cosine VCO that swaps its phases for negative control voltages ("positive and negative frequencies") ? It has a wide range (0 to 10 kHz for 0 to 10 control V) and -40dB distortion.
www.edn.com/filtered/pdfs/contents/images/341451.pdf
Wiring up one half of this circuit since I am only interested in positive control voltages, I get a triangle wave, not a sine wave.
UofMEShop
PostPosted: Wed Jan 07, 2009 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Doing this : Zener to top of 10K trim instead of to 820K/10K junction, 100K (instead of 820K) to 10K trim's wiper, replace 4.7M with 1M gets rid of the clipping. The amplitude varies from 8 to 26 V pk-pk using the 10K trim. One output's negative amplitude is a little smaller than the other's. Thanks.
frijitz
Audio files: 54
PostPosted: Wed Jan 07, 2009 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
thumright
Slightly displaced or unsymmetric or unequal outputs are due to OTA offsets.
You may be able to get lower distortion by increasing the 1M positive feedback resistor.
Ian
vladosh
PostPosted: Fri Aug 19, 2011 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
i really wanna build the first small version of this vco ..however got a few questions so i hope someone can share their wisdom Smile
from what i read ..to modify it for audio range one needs to change the caps to 120 pF ,change the 4.7 M resistors to 1M .. i got a question concerning the expo converter as i don't have temcos and on the other hand i don't mind if there is a bit of drift or if they are a bit out of tune . I was thinking if it's possible to use the Thomas Henry VCO1 expo converter http://www.birthofasynth.com/Thomas_Henry/pdf/VCO-1/vco1_schem1.pdf..seems it's something i can handle on a stripboard ,i was even thinking if it's possible to use the expo converter from here http://www.modular.fonik.de/files/EFMforum/orgEFMfiles/efm-4600-doc_01.pdf from the 4614 VCO as i already got that one working .. it's possible that i understood all wrong btw Smile as i'm a noob .
any help is great ..as i would really make at least two of these sine/cosine vco's .. thanks
Vlad
frijitz
Audio files: 54
PostPosted: Fri Aug 19, 2011 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
vladosh wrote:
I was thinking if it's possible to use the Thomas Henry VCO1 expo converter http://www.birthofasynth.com/Thomas_Henry/pdf/VCO-1/vco1_schem1.pdf..seems it's something i can handle on a stripboard ...
That would probably work OK.
...,i was even thinking if it's possible to use the expo converter from here http://www.modular.fonik.de/files/EFMforum/orgEFMfiles/efm-4600-doc_01.pdf from the 4614 VCO as i already got that one working ..
No, that won't work. You need a design that can drive current into the negative supply level.
You could use the converter shown for the second schematic, leaving out the "C" and "D" transistors.
Also, to be sure you are aware, Yves has a nice adaptation of this circuit that might be helpful to you.
Ian
vladosh
PostPosted: Fri Aug 19, 2011 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot Smile
I'll try that with Thomas Henry VCO-1 expo converter this coming week .. i hope it'll work out ..
greetings
Vlad
drapdap
PostPosted: Thu Aug 25, 2011 2:13 am    Post subject: Reply with quote  Mark this post and the followings unread
http://yusynth.net/Modular/EN/QUAD-LFO/index.html
I also have a question as i use this a lot (very cool circuit) and i'd like to have 4 sine outs. Sometimes when i use it for mixing/panning they seem just too, hm, spikey. Smile
No other way around than to build 4 tri to sine converters?
widdly
PostPosted: Wed Oct 12, 2011 9:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Serge Quadrature VCO has a hold input that takes a gate a freezes the VCO output at it's current level. When the gate goes low it resumes from the point it was frozen.
Is that possible with this design? Maybe a cmos switch on the cv input to force it to ground? I'll have a play on my breadboard.
frijitz
Audio files: 54
PostPosted: Thu Oct 13, 2011 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Should be possible. You'd want to gate in a large enough negative CV to bias the expo converter off (without putting to much reverse bias on the expo transistors, of course). Perhaps a CMOS switch from the summing node through 220k to the negative supply.
Or do it externally by inverting your gate and putting it into an FM input.
Ian
widdly
PostPosted: Thu Oct 13, 2011 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ian. I like your idea of inverting the gate and feeding it to an FM input.
reppiks
PostPosted: Fri Jan 04, 2013 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested in trying out the first schematic in this thread for my first DIY electronics project (I did basic practical electronics at school and have a degree in theoretical physics, but that didn't cover any electronics/circuitry aside from the theoretical background) - how feasible do you think that is for a beginner's project? I don't need the additional phases so am not wanting to tackle the larger second schematic.
I'm planning for this to be my 2013 new hobby/project but probably won't get much time to dip into it for a while yet.
LFLab
PostPosted: Fri Jan 04, 2013 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Without having looked at this in depth, I think something simpler and more documented will suit you better. Have you had a look at some of the Yusynth projects, or the MFOS website?
The more people building a certain project the more information is available, and more people will be able to help you.
In this particular project, the last reply before yours was well over a year ago. You might very well make this work, but nothing is more frustrating than a project that takes more time to get working properly.
reppiks
PostPosted: Fri Jan 04, 2013 2:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for you reply.
Yeah, you're probably right I should start with some other stuff first that has more support documentation etc, I looked around the MFOS site recently.
But still, I am very interested in this circuit and want to get to it as soon as I feel confident tackling it... I wonder what level of trickiness it would entail...
Cheers!
LFLab
PostPosted: Fri Jan 04, 2013 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
If it is the functionality you are looking for, did you look at the Yusynth quadrature LFO?
reppiks
PostPosted: Fri Jan 04, 2013 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I'll check it out (found the link: http://yusynth.net/Modular/EN/QUAD-LFO/index.html)
Although actually I'm not interested in the first place in the quadrature functionality (though that does look super-fun), my main interest was in finding a sinecore VCO for nice sines. Tracking/stability is not necessary, and other waveshapes are not necessary (I have other VCOs that cover me there)
Cheers!
frijitz
Audio files: 54
PostPosted: Fri Jan 04, 2013 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, come now. It's a simple circuit -- just two chips. And I am usually around to provide help. Sheesh!
Ian
frijitz
Audio files: 54
PostPosted: Fri Jan 04, 2013 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
What exactly do you need for frequency control? The first schematic just has a knob, so you might need to add an expo converter. If you need a 1V/Oct input, I recommend the Yusynth version.
Ian
LFLab
PostPosted: Fri Jan 04, 2013 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Ian
lol, alright, alright Very Happy
reppiks
PostPosted: Fri Jan 04, 2013 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd like to have attenuated Lin and Exp FM inputs, 2 of each. 1v/oct not required.
knutolai
PostPosted: Wed Dec 11, 2013 7:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
What supply voltage would you use for the "VC quadrature sinewave oscillator"? I cant seem to find it anywhere in the tread. The reason I ask is I know this is more of a synth forum while I'm more of a guitar stompbox person. So could the circuit be operated at 9 volt unipolar supply or 4,5 volt bipolar supply?
frijitz
Audio files: 54
PostPosted: Wed Dec 11, 2013 9:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ooops! It's for +/- 12V.
Ian
medbot
PostPosted: Tue Sep 30, 2014 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry if this is a silly question, but in the first simple schematic posted, which pin is the arrow going into on the 13700? Thanks!
frijitz
Audio files: 54
PostPosted: Tue Sep 30, 2014 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's the control current pin (1/16).
Ian
medbot
PostPosted: Tue Sep 30, 2014 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ian
Thanks for the quick answer Ian. If I could get just one more from you - what do the 1 and 3 pins on the frequency pot connect to? +/- voltage was my best guess but I'm willing to be wrong.
Edit: looks like I was right and it's working great. Thanks for the great little circuit, it should go nicely with my ring mod Very Happy
