Ground question...
Page 1 of 1 [2 Posts]
eXisteNz
PostPosted: Sat Apr 19, 2014 4:42 pm    Post subject: Ground question... Reply with quote  Mark this post and the followings unread
Hello, i have a doubt about a possible issue: since there are Two grounds loops, analog and digital, and i use a metal front panel, should i prevent to interact each other insulating components of one of them from The panel (analog one)? Or digital ground doesnt affect analog ground and i can let all metal fp components come in contact with The metal faceplate?
inlifeindeath
PostPosted: Mon Apr 28, 2014 11:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
the analog and digital grounds likely connect at some point. The key is to keep them separate until they reach the power supply to avoid as much noise off the analog side as possible. You shouldn't need to insulate the panel from either ground point.
