June Solstice Streaming Event
Page 2 of 3 [65 Posts]
Audio files: 406
PostPosted: Mon Jun 16, 2014 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Acoustic Interloper wrote:
Muied Lumens wrote:
How does this look for everyone? Please sound out if it is not suitable for you or you want more time to perform... (hint hint) Wink
Rob, looks fine. I can take a (hint hint) and do 60 minutes. Not sure how that shuffles things.
I may be able to join in on the collab, depending on when our day guests leave. Current estimate has their departure around 22GMT. They have little kids, so it might be a bit earlier. I will know by the day of.
Thanks.
Dale
OK, you have an hour now, start time unchanged. Thanks! Smile
Blue Hell and Robert Dorschel have been moved back by 30 minutes.
Muied Lumens Base Star
rdorsche
PostPosted: Mon Jun 16, 2014 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey folks... what's the link to the actual broadcast channel gonna be for listeners? Just on the standard EM radio link page? Or another? Also, is there a poster?
Audio files: 406
PostPosted: Mon Jun 16, 2014 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Antimon wrote:
I am interested to join in on the ring thing! Smile
Great! We need a name for it... Ring Jam? Orbit Remix? Tumble Driver?
Suggestions welcome.
Edit: Ring Thing is good too.
Audio files: 406
PostPosted: Mon Jun 16, 2014 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, the main channel: http://srv3.electro-music.com/~janpunter/play.php/port_8050.m3u
I will finish the poster later. There is a preliminary poster in the first post of this thread.
Audio files: 648
PostPosted: Mon Jun 16, 2014 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Muied Lumens wrote:
OK, here's a thought for the hour which is the break, ie 22:00 - 23:00...
It may be messy, but it's an experiment so here goes:
Several (minimum 2) people stream in a circular fashion, listening to one other streamer and sending it on to the next. The only rule is that you have to change the incoming stream in some way, be it using effects or trying to interpret it using your own instrument (or even voice). You may also add your own material if you wish.
It has to start off in some way, so it starts by everyone playing something until they hear something coming into their player, at which point you may continue to play or concentrate on changing the material.
Everyone records their outgoing stream and posts it after. It is therefore perhaps not really a live (or at least centralised) event, but it should be interesting anyhow.
If it's in a loop with the last person streaming back to the first person then it'll be exactly what I had in mind for Mr. Kite's Public Cyclotron Show clown .
I did a test at some point of which a segment was played on Organized Sound and I think I even have a half finished poster for it some where.
The idea was to use all public ports (but private ports work aswell) and listeners can tune in to any of those ports to listen to the cyclotron at different stages.
Audio files: 406
PostPosted: Mon Jun 16, 2014 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that's exactly it! I do remember someone mentioning it but I couldn't recall who.
PostPosted: Mon Jun 16, 2014 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I ran "midsommarkrans" through google translate and it said "midsummer wreath". Dunno if that sounds as good in english as it does in swedish... :/ Anyway, "Midsummer Stream Wreath", maybe?
For those who wonder what I'm talking about:
https://www.google.se/search?q=midsommarkrans&client=safari&rls=en&tbm=isch&tbo=u&source=univ&sa=X&ei=kE6fU-mML6OwywP0xILgCw&ved=0CCIQsAQ&biw=1033&bih=990
Audio files: 406
PostPosted: Mon Jun 16, 2014 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, in the end I decided I needed something descriptive for it this time..
Besides, it almost looks like "Midsummer Wrath". Laughing
Poster added to first post in this thread.
Acoustic Interloper
Audio files: 87
PostPosted: Tue Jun 17, 2014 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
The poster looks good!
"AcidThrasH" should say "AcidTrasH" Smile
Thanks.
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
Audio files: 406
PostPosted: Tue Jun 17, 2014 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
Thanks! I will fix it asap.
Audio files: 406
PostPosted: Tue Jun 17, 2014 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
june solstice 2014 fix
 Filesize:  442.79 KB
 Viewed:  418 Time(s)
Audio files: 156
PostPosted: Wed Jun 18, 2014 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would like to participate in the circle thing too. Sounds like a lot of fun.
Audio files: 406
PostPosted: Wed Jun 18, 2014 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great! Very Happy
Audio files: 251
PostPosted: Wed Jun 18, 2014 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
the event page is up now at : http://electro-music.com/wiki/pmwiki.php?n=Radio.NextSpecialEvent
Acoustic Interloper
Audio files: 87
PostPosted: Wed Jun 18, 2014 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Jan Razz
rdorsche
PostPosted: Thu Jun 19, 2014 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Yippee!
Hey, question... since I'm last, is it okay if I go long?
Audio files: 406
PostPosted: Thu Jun 19, 2014 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
rdorsche wrote:
Yippee!
It is more than OK, it's great! Very Happy
rdorsche
PostPosted: Thu Jun 19, 2014 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Great! But how would I indicate that I'm done to the stream? As in, so the standard stream picks up when I'm done? Or the moderator knows I'm done, via chat?
Audio files: 406
PostPosted: Thu Jun 19, 2014 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
You let it be known in the chat, so a stream operator can switch back to playlist.
Audio files: 251
PostPosted: Thu Jun 19, 2014 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
And talking about stream ops ... we need more stream ops .. desperately Shocked
mtvic
PostPosted: Thu Jun 19, 2014 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
circle me in if possible.
will be testing stream on friday
port 8130?
Audio files: 251
PostPosted: Thu Jun 19, 2014 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
8130 - check
the details are at the event page.
Audio files: 648
PostPosted: Sat Jun 21, 2014 5:25 am    Post subject: PHOBoS & Muied Lumens - Summering Rummersing
Subject description: mini ringjam test session
Here's a mini ringjam test session between Muied Lumens and myself, recorded last night. Cool
PHOBoS & Muied Lumens - Summering Rummersing (Jun 21, 2014).mp3
June Solstice 2014, mini ringjam test session
 Filename:  PHOBoS & Muied Lumens - Summering Rummersing (Jun 21, 2014).mp3
 Filesize:  43.18 MB
 Downloaded:  1149 Time(s)
Audio files: 648
PostPosted: Sat Jun 21, 2014 4:57 pm    Post subject: Antimon - Miniature Islands
Subject description: EM June Solstice 2014
Here's Antimon's amazing set
EM June Solstice 2014 - 03. Antimon - Miniature Islands.mp3
Antimon live @ EM June Solstice 2014
 Filename:  EM June Solstice 2014 - 03. Antimon - Miniature Islands.mp3
 Filesize:  54.77 MB
 Downloaded:  1153 Time(s)
Audio files: 648
PostPosted: Sat Jun 21, 2014 6:30 pm    Post subject: Mosc
and here's Mosc's beautiful solo set sunny
EM June Solstice 2014 - 05. Mosc.mp3
Mosc live @ EM June Solstice 2014
 Filename:  EM June Solstice 2014 - 05. Mosc.mp3
 Filesize:  26.96 MB
 Downloaded:  1171 Time(s)
