tokyomatik
Audio files: 6
Posted: Sun Apr 19, 2015 6:48 pm Post subject:
PS3100 v3 indidual CV/LFO depth attenuator ?? |
hi! I have a version v.3 of the resonators, and i would like to use attenuators on the single cv inputs like for the new version, so since they are normaled to the internal LFO what should i do with the LFO depth pot pads? can i replace it with a resistor between pin 1 & 2 and 3 to ground?
i'm trying to build a kind of Double Trouble, so also the x-panner is involved, but i would like to have single outs for the resonators using switched jacks before to go the 3 inputs jacks of the panner so this could give the option to run the single resonators outs to a delay or a reverb, before to go back to the panner....
does it sound doable?? |
Posted: Mon Apr 20, 2015 12:58 am Post subject:
Re: PS3100 v3 indidual CV/LFO depth attenuator ?? |
tokyomatik wrote: | hi! I have a version v.3 of the resonators, and i would like to use attenuators on the single cv inputs like for the new version, so since they are normaled to the internal LFO what should i do with the LFO depth pot pads? can i replace it with a resistor between pin 1 & 2 and 3 to ground? |
no resistor. just solder a wire from pad '2' to '3'. pad '1' (GND) is not needed.
Quote: | i'm trying to build a kind of Double Trouble, so also the x-panner is involved, but i would like to have single outs for the resonators using switched jacks before to go the 3 inputs jacks of the panner so this could give the option to run the single resonators outs to a delay or a reverb, before to go back to the panner....
no problem at all. you just might want to solder a short protection resistors (330R to 1k) between the sngle outs of J8 and the jack sockets. _________________
Tech Buddy at Random*Source |
tokyomatik
Audio files: 6
Posted: Mon Apr 20, 2015 1:42 am Post subject:
u mean resistors between the jack socket of the single outs?? |
Posted: Thu Apr 23, 2015 9:35 am Post subject:
tokyomatik wrote: | u mean resistors between the jack socket of the single outs?? |
exactly. this will protect the opamps output. you might have seen those 1k resistors in other schematics as well. _________________
