today> Muied Lumens Frequencies
CGS49 Dual CMOS filter - Odd problem with both filters
Page 1 of 1 [4 Posts]
Flareless
PostPosted: Mon Jan 23, 2017 11:08 am    Post subject: CGS49 Dual CMOS filter - Odd problem with both filters Reply with quote  Mark this post and the followings unread
I've built a few of these modules but this one seems to be giving me an interesting problem;
When I run an oscillator into Filter 1 it's sound comes out the High Pass and Notch filters loud and clear but when I switch to Low Pass or Band Pass the volume decreases sharply. Further, the Frequency pot has no effect on the sound no matter which selection I make. The CV inputs don't either. The Resonance and Distortion % pots seem to work fine.
The exact same thing happens on Filter 2.
I've wired this module with the -15V going to the Frequency knob rather than 0V and with the spread coming from both CVSN on Filter 1 and pin 3 of the TL072 (where it meets the 2K2 resistor).
This has worked for me on other CGS49 modules I've built but this is a strange problem that I can't seem to figure out
Does anyone have suggestions as to what I might do to test / fix this problem? Any help would be greatly appreciated.
Rich
Lower West Side Studio
Fizzbin on SoundCloud
Flareless
PostPosted: Mon Jan 23, 2017 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a copy of the wiring diagram I used...
Rich
Flareless
PostPosted: Wed Jan 25, 2017 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
This turned out to be due to bad CA3080 chips that I purchased from China.
Thanks for the tip Ken!
Rich
wackelpeter
Audio files: 10
PostPosted: Thu Jan 26, 2017 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Think i have some similar issue... can't recall it exactly right now, but i think it was BP and ??? which were very quiet compared to 2 of the other Outputs...
Good idea to swap the CA3080... but i think i didn't got mine from China/eBay... don't know... i will try it out as the rest seems to be correct from what i remember...
