Joined: Mar 11, 2014 Posts: 746 Location: New Zealand
Posted: Sun May 17, 2015 3:07 am Post subject:
Not at all, didn't answer since I'm not 100% on what's going on myself. |
tokyomatik
Audio files: 6
Posted: Sun May 17, 2015 10:12 am Post subject:
u mean out of body experiencies?? |
lunaire
Posted: Mon Jun 01, 2015 7:42 pm Post subject:
I think this delay might be so good people dont want u to have it.. lol
Im building one this week and wondering same things btw |
tokyomatik
Audio files: 6
Posted: Thu Jul 16, 2015 12:01 pm Post subject:
inlifeindeath wrote: | PickNick wrote: | i'm still not sure what kind of regulator is 1702...
mcp1702?
can i use 7805? |
yes, it's just a 5v line for the delay chip. 7805 work fine. |
I'm not able to find any mcp1702..... so good to know that i can simply replace it with a 7805.....but do they have the same pinout?? |
ym2612
Posted: Mon Aug 03, 2015 9:19 am Post subject:
So, I laid out my own Zeitgeist PCB from the schematic, and last night I finished building it into a stompbox. I really like the tape-like sound it gives, but one or more of the opamps on it seems to self-oscillate really easily. Has anybody else encountered this? I may have to pick over it with a scope and maybe add some more bypass caps. |
fluxmonkey
Posted: Mon Aug 03, 2015 9:36 am Post subject:
tokyomatik wrote: | inlifeindeath wrote: | PickNick wrote: | i'm still not sure what kind of regulator is 1702...
mcp1702?
can i use 7805? |
NO, different pinout (as i found from hard experience... released the majic smoke). i don't have the detail to hand, check the datasheet _________________ www.fluxmonkey.com |
gasboss775
Posted: Thu May 18, 2017 6:32 am Post subject:
tokyomatik wrote: | I'm checking the board with the components and I have some questions:
what are the pots function names?? (from left to right) |
Late reply but in case you are still wondering:
From Left to Right ( P4, P3, P2, P1 )
Input Level, Wet/Dry mix, Modulation Depth ( from external CV ), Delay Time.
Quote: | The CV input is to control the delay time? |
Yes
Quote: |
what is SENSOR doing?(HDR 10) |
It is an LDR, presumably to control delay time according to light level.
Quote: |
what are the functions of JUMPER and the two HDR 3? jumpers for a different settings ? |
HDR_3 allows you to bypass the external CV option the jumper allows you to bypass the LDR if you don't want to use it.
Quote: |
the JUMPER next to the led says + and -, should I consider - as Ground?? |
Yes -Ve appears to be ground in this circuit. As it works from a single supply.
Quote: |
I will try to etch this board in these days, not so many parts and looks also an easy build...any recomendation? |
Can't say haven't built it yet, but will definitely breadboard it to try it out. |
