Nord Modular G2 Editor 1.62 and OS X High Sierra 10.13.6
Page 1 of 1 [6 Posts]
JennoJackson
PostPosted: Fri Jun 07, 2019 1:54 pm    Post subject: Nord Modular G2 Editor 1.62 and OS X High Sierra 10.13.6 Reply with quote  Mark this post and the followings unread
Hi, my first post here. I have my G2 running with Nord Modular G2 Editor 1.62 on OS X High Sierra 10.13.6. But unfortunately it's not running stable. I get non reproducible errors like "Major Error" and "Usb Connection Lost". Does anyone have the same problems, same system or an idea how to fix it?
Thanks in advance
Jens
Audio files: 243
G2 patch files: 319
PostPosted: Fri Jun 07, 2019 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome Jens,
not having a solution ... but having the same issues here, my OSX version is a bit later 10.14.2 - Mojave. not really using the G2 lately .. but would be interested to see a fix too.
Jan.
JennoJackson
PostPosted: Sun Jun 09, 2019 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I send a request to North Technical Support. Let's see if they can help.
Rudt
PostPosted: Sun Oct 06, 2019 10:39 am    Post subject: OSX later versions
Subject description: Parallels or VMWare
I'm looking into a solution to run the G2 on later versions of OSX. I've tried Wine to no avail and have also tried parallels and it didn't work either.
of course I had problems installing the USB driver on both for some reason
Rudt
PostPosted: Sun Oct 06, 2019 8:48 pm    Post subject: I found what the problem is Reply with quote  Mark this post and the followings unread
Hi. I'm able to get my G2 working on every mac OS up to Mojave using 1.62 editor. Also able to get it to work on Parallels on a Mac. How? Use an extremely short USB cord. Works fine on Mojave (using an old mac with a regular usb 3 input). Not sure if it works with the newer usb ports on macs.
comma
PostPosted: Wed Nov 13, 2019 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you happen to get any word on this from Nord support?
