Editor with Touchscreen
Page 1 of 1 [5 Posts]
sebber
G2 patch files: 33
PostPosted: Fri Aug 16, 2019 2:51 pm    Post subject: Editor with Touchscreen Reply with quote  Mark this post and the followings unread
Hello everybody,
I've got a little Windows 10 computer with a touch screen here and of course I tried it right away with my favourite synth. Connections work and all and I can drag and drop modules, but I can't patch cables. Everytime I tap on an input or output it either shows me the options menu or it wants to draw a rectangle. Can anybody advice on how to do it?
Best
sebber
Fish don't swim. They dive.
sebber
G2 patch files: 33
PostPosted: Sat Aug 17, 2019 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
To reply to myself: a stylus is needed unless the touch screen is huge.
Burp
G2 patch files: 7
PostPosted: Mon Oct 07, 2019 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Seems like a nice solution. What is you're experience after a longer time in use?
if you don't know where you're going, you will allways arrive
sebber
G2 patch files: 33
PostPosted: Thu Oct 10, 2019 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
My touchscreen only supports passive touch pens. Those have a rather large tip and with these it's pretty impractical to work. The tip is much larger than the in- and outputs, for example.
It should work nicely on a better screen with a small (active) pen.
Burp
G2 patch files: 7
PostPosted: Fri Oct 11, 2019 2:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for sharing you're experience, seems not that ideal after all.
