 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
8-mode modal synthesis patch
Page 1 of 1 [9 Posts]
Chet
G2 patch files: 35
PostPosted: Sun Aug 28, 2005 8:47 am    Post subject: 8-mode modal synthesis patch Reply with quote  Mark this post and the followings unread
Attached is a patch that does Tassman-style modal synthesis: 8 parallel high-resonance bandpass filters, excited by an input impulse.
The G2 bandpass filters don't seem well-suited for this kind of synthesis: the duration of their ringing resonance is either too short, or continuous. So there's an additional envelope/vca that cuts off the sound when you release a key.
The mod wheel controls the timbre and envelope of the input impulse.
Only the first variation is programmed.
Modal6.pch2
 Filename:  Modal6.pch2
 Filesize:  3.5 KB
 Downloaded:  1198 Time(s)
eposk
PostPosted: Sun Aug 28, 2005 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
nice patch, has a cool sound to it. fun to play with too!
Audio files: 143
PostPosted: Sun Aug 28, 2005 11:16 am    Post subject: Reply with quote  Mark this post and the followings unread
This is very cool.
I bet when the 1.4 version with Palle's genetic variation devloper will work very well with a patch such as this.
eposk
PostPosted: Sun Aug 28, 2005 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
when is 1.4 coming out? i havent heard any news about it for a while...
Audio files: 143
PostPosted: Sun Aug 28, 2005 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Question
Rob
G2 patch files: 109
PostPosted: Sun Aug 28, 2005 3:46 pm    Post subject: Re: 8-mode modal synthesis patch Reply with quote  Mark this post and the followings unread
Here is a little trick that gives more precise control over the ringing time of a filter.
How it works:
Internally a 12 dB filter is on the point of self-oscillation and the resonance is damped by feedback of the bandpass output to the input. By using an 'external' resonance feedback path and some scaling it is possible to get more precise control. Note that it is best to set the filter resonance fully open and invert the bandpass output before the feedback. Then it is just a matter of which mixer knob curve to use, and optional extra range scaling, to create the desired 'feel' for a decay knob.
LongFilterRinging.pch2
Trick to get precise control over the ringing time of a pulse excited 12dB filter in bandpass mode.
 Filename:  LongFilterRinging.pch2
 Filesize:  2.17 KB
 Downloaded:  1245 Time(s)
Chet
G2 patch files: 35
PostPosted: Tue Aug 30, 2005 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the tip, Filtermeister! Smile
I'll add that to the patch. Looking back on it, there's some other stuff I'd like to add, too.
Chet
G2 patch files: 35
PostPosted: Wed Aug 31, 2005 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a subsequent version that incorporates Rob's feedback mechanism. It also includes a tuned resonator, similar to the hollow tubes under a set of vibes. The resonator can be turned off via a mixer knob in the 'effects' section.
Modal8.pch2
Tassman-style struck bar w/Rob's feedback network and a tuned resonator
 Filename:  Modal8.pch2
 Filesize:  4.47 KB
 Downloaded:  1038 Time(s)
Chet
G2 patch files: 35
PostPosted: Wed Aug 31, 2005 6:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yikes, I just found out that I posted the wrong patch. The correct one is here. Embarassed
Modal9.pch2
A correction to modal8
 Filename:  Modal9.pch2
 Filesize:  4.71 KB
 Downloaded:  1130 Time(s)
