<on air> Muied Lumens Frequencies
 Forum index » electro-music.com
Electro-music.com Chat Room now operational
Page 1 of 2 [35 Posts]
Audio files: 140
PostPosted: Sat Oct 09, 2004 2:39 pm    Post subject:  Electro-music.com Chat Room now operational Reply with quote  Mark this post and the followings unread
After a bit of discussion and a lot of code hacking and testing, the new electro-music.com chat room is operational. To use the chat room, just click on the "Chat Room" menu on the upper right of every forum page.
The chat software is a Java Application and it's been tested on PC and MAC. I had trouble using Mozilla, but aftering upgrading to 1.8a everything seems to work fine. It works with Safari and with IE.
I don't know how much use we'll make of this, but sometimes there is a need for chatting and if members arent logged on to AIM or something, it's difficult to do so. With this facility, any member can get on and join immediately.
The chat room also supports private connections which my be appropriate sometimes.
Thanks to everyone who helped test this, especially Static Strobe Emitter and JKN.
If you have any feedback, questions, or complaints, please post them here.
EDIT - Sept 30, 2005:
If you don't have Java or just want to use another program you can go to
irc.blitzed.org
port 6667
channel #electro
on any IRC program of which there are many.
EDIT - May 18, 2006
Javascript is a sort of a scripting language built into the web browser. For running Java programs (not the same as Javascript) you need to install the Java Runtime Environment (also called JRE or "Java engine"). Most bowsers automatically install the JRE, but some do now. If you need the Java engine, the see http://www.java.com/en/download/index.jsp
PostPosted: Fri Sep 30, 2005 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried using the chat room, but all I get is a blue box with a load of emoticons across the middle. How do you actually use it?
PostPosted: Fri Sep 30, 2005 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey.. that is probably the app loading. It looks like that until the java thingie is fully loaded.
Are you using OS X or XP or.. ??
Flickr
PostPosted: Fri Sep 30, 2005 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
XP, sorry 'bout that. I'll try again and be a bit more patient this time.
PostPosted: Fri Sep 30, 2005 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Nah, it says "done" and there's no traffic, so I don't think anything is loading.
PostPosted: Fri Sep 30, 2005 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm on it right now with strobe- talking a lot of bollocks. Come on get it together!
PostPosted: Fri Sep 30, 2005 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
It's been sitting there for about 15mins and nothing.
Maybe I'm not good enough Crying or Very sad
Audio files: 140
PostPosted: Fri Sep 30, 2005 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
If you have IE, try this link
click here
It won't work on Firefox. It will test your Java installation.
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Sep 30, 2005 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
you mean IE with XP Question
PostPosted: Fri Sep 30, 2005 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, don't worry about it mosc.
I just found out I don't even have Java!
And it's about 190MB to download which I can't be bothered with at the moment.
Maybe I'll get it from TAFE when I go back, they've got a faster connection than me, and I can do it during the day.
Audio files: 140
PostPosted: Fri Sep 30, 2005 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, you need Java installed. Smile
Or, you can go to
irc.blitzed.org
port 6667
channel #electro
PostPosted: Fri Sep 30, 2005 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I presume everyone's chatting in the new chatroom. Unfortunately I think the novelty wears off quite quickly- as it's like strolling around in the buff!
I think where this could work well would if you could choose individual members to talk to rather than everybody all at the same time.
PostPosted: Fri Sep 30, 2005 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
It is actually the "old" chatroom. It has been resurrected.
Flickr
PostPosted: Fri Sep 30, 2005 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
:D
ahh- okay :)
Audio files: 140
PostPosted: Fri Sep 30, 2005 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Tom, you can actually do this. When you are in the chat room, double-click on the name of someone who is also logged on (list on upper right of the window). It will open a new window where you have have a private converstion. Cool
paul e.
PostPosted: Fri Sep 30, 2005 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
same here...
os x 10.3.9
haven't updated java in a while, so i assume this is the issue
Spiral Recordings
Audio files: 140
PostPosted: Fri Sep 30, 2005 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
elektro80 and v-un-v have had good luck with OSX, but I haven't. It may be better to use iChat. I tried updating to the 1.5 version of Java on my Mac and the install didn't work. It said you need 10.4 to run it. Crying or Very sad
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Oct 01, 2005 12:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I am using OSX 10.4.2 and it works flawlessly
destroyifyer
PostPosted: Tue May 16, 2006 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
it looks like i'm a year late for this topic. oh well, i'll just have to check out that chat room now. damn, i'm slow.
Audio files: 140
PostPosted: Tue May 16, 2006 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
It would be nice to see more people taking advantage of the chat room. During our live webcasts the chat room becomes the center of attention. Smile
PostPosted: Tue May 16, 2006 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just tried it again. (I've been interested in trying it out for a loooong time) But it's the same as it was in September. Just a line of emoticons. Crying or Very sad
Audio files: 140
PostPosted: Wed May 17, 2006 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
That probably means you don't have a good Java engine loaded or you have Java disabled in your brower or OS secruity settings. Can you run other Java apps OK?
PostPosted: Wed May 17, 2006 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah Java scripts on Web pages run fine. And I know it's not disabled.
Audio files: 140
PostPosted: Wed May 17, 2006 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
This chat room client is Java - not Javascript. They are two totally different things.
Try these demos, my guess is they won't run either.
http://java.sun.com/applets/jdk/1.4/index.html
If they do, then more thinking is necessary - always a challenge.
PostPosted: Wed May 17, 2006 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah Mosc, you're right. They don't run.
