Variable step-length sequencer
Page 1 of 1 [5 Posts]
Rob
G2 patch files: 109
PostPosted: Sun May 07, 2006 10:35 am    Post subject: Variable step-length sequencer Reply with quote  Mark this post and the followings unread
This building block uses a SeqLev and a SeqCtr module to create a programmable clock divider for another sequencer. The duration of each step can be chosen from a table of 16 preprogrammed durations, ranging from 1/32th to 3/4th. Triplet values like 1/24, 1/12, 1/6 and 1/3 are also available in the table.
How it works:
The heart of the divider is a binary counter connected to a DA module. The output of the DA module is compared to a value that comes from a table stored in a SeqCtr module. Depending on the value read from the SeqCtr the binary counter counts a certain number of times. The output of the compare module resets the binary counter and is used as the clock for other modules. One of these is a SeqLev that controls which value is read from the SeqCtr module.
Some additional modules take care of some household jobs to get everything working.
So, each step in a sequence can have its own independent time duration (stored in the SeqLev module), chosen from sixteen possible durations (read from the SeqCtr module).
Disadvantages:
The clock signal for the binary counter is taken from the 1/96th output on the ClkGen module, which means that the swing parameter on the ClkGen will have no effect.
Have fun,
/Rob
VariableStepLengthSequencer.pch2
Example for how to create variable step durations for step sequencer modules
 Filename:  VariableStepLengthSequencer.pch2
 Filesize:  3.32 KB
 Downloaded:  743 Time(s)
mother misty
G2 patch files: 130
PostPosted: Mon May 15, 2006 1:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi rob,
Nice sequencer, but I've got some questions if you don't mind.
What are those 2 yellow modules at the bottom (s&h and constant switch) suposed to do,
I see the s&h isn't connected?
You didn't connected the last output from the binary counter, is there a reason for this?
greets,
misty.
Rob
G2 patch files: 109
PostPosted: Mon May 15, 2006 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
mother misty wrote:
Hi rob,
greets,
misty.
Aah, those two unused modules are there for test purposes: when disconnecting the Ctr input on the SeqCtr1 modules and connecting it to the S&H1 output it is possible to select a certain step on the SeqCtr1 module manually, by setting a value on the ConstSwitch1 module. This I used to check if the rhythmic divisions were indeed correct. The S&H1 makes sure the change to another division starts at the beginning of a bar. And another little curiosity is that the selection range of a SeqCtr module is from 0 up to but not including +64, whcih can be checked with that constant module. This SeqCtr conrol range thingy is also the reason why that Clip1 module is there, it clips a possible +64 value coming from the SeqLev module to a value of +63.5, so the SeqCtr won't park.
The idea is to have a lookup table that stores possible division rates (theSeqCtr1 module) and have another sequencer (SeqLev1) define an address in this table. Then the table value is used to let a programmable counter counter the number of 1/96 clockticks selected from the table. The SeqCtr1 module is used as the lookup table where the amount of upwards counts is stored before the BinCounter1-DAConv1-CompSig1 combination (the programmable counter ) is reset.
The D7 input on the DAConv module is actually the sign bit, it negates the DAConv output value as defined by the other seven inputs. Basically the DAConv module can output a range between -64 and +64 in half steps, but for this particular application only 16 values in a range between 1.5 and 36 are needed, and these are all positive values. So, basically I let the BinCounter1-DAConv1 module combination count upwards from 0 to +64 in half steps, and not upwards from -64 to +64 in half steps.
(The reason for this SeqCtr Ctr input range is that this way two of those modules can easily be 'chained' to give a 32 locations table, for this all one has to do is add 64 units to the Ctr signal and feed it to the Ctr input of a second SeqCtr module which now reacts to the negative range of the Ctr signal. See attached patch, where two SeqCtr modules are used in a table lookup configuration to create rhythm variations.)
/Rob
32LocationLookupTable.pch2
Patch where two SeqCtr modules are used to create a 32 location lookup table. In this patch that lookup table is used to create rhytmic variations. Of course there is some other interesting stuff here, like the patent pending Kassen-Rob digitizing brickwa
 Filename:  32LocationLookupTable.pch2
 Filesize:  4.12 KB
 Downloaded:  675 Time(s)
mother misty
G2 patch files: 130
PostPosted: Tue May 16, 2006 1:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the explination Rob, much appreciated!
W.T.
G2 patch files: 11
PostPosted: Fri Oct 20, 2006 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
very interesting! can't wait to get home and explore this patch.
Thanks in advance Wink
Niio2
