Plucked string with controllable pluck & pickup coil points
Page 1 of 1 [2 Posts]
Chet
G2 patch files: 35
PostPosted: Mon May 15, 2006 9:54 am    Post subject: Plucked string with controllable pluck & pickup coil points Reply with quote  Mark this post and the followings unread
This is a simple string with:
Controllable pluck point, using the "Pluck Locatn" knob. At zero, the pluck point is at the far edge of the string, where it makes almost no sound. At 64, the pluck point is in the center of the string, where it makes a hollow, woody sound.
Optional electric pickup coil with controllable location, using the "Pickup Locatn" knob. At zero, the pickup coil is at the far edge of the string. At 64, the pickup coil is in the center of the string.
The pickup coil can be defeated by switching the "Body" switch to "Acoustc".
This uses three string oscillators, which should typically track the same pitch.
To change the string's timbre and decay time, use the "Decay" and "Damp" knobs on the "String Delay" string oscillator.
PluckPointString.pch2
 Filename:  PluckPointString.pch2
 Filesize:  2.42 KB
 Downloaded:  1577 Time(s)
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Sun Jun 04, 2006 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another great one that I missed. This one sounds quite nice, but is very simple (and easy to tweak Smile). I never bothered looking too much into the String Osc after reading the posts about how it's unsuitable for physical modelling... I don't see the problem...
Thanks Chet Smile
