TL071 offset pins?
Page 1 of 1 [3 Posts]
Coriolis
PostPosted: Mon Oct 23, 2006 1:23 pm    Post subject: TL071 offset pins?
Subject description: Used in CGS synthacon vcf?
Looking at the schem (CGS 35) from Ken Stone's site, there is no info on whether pin 1 & 5 (offset pins) are connected to anything. Looking in the datasheet, I see they are used for adjusting voltage offset between the pos and inv inputs - none of that going on in the cgs schem that I can see.
Just to make sure, as I'm doing my own layout: The offset pins shouldn't be connected to anything? Ground them out? Leave them?
Thanks
C
Scott Stites
Audio files: 96
PostPosted: Mon Oct 23, 2006 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looking at his board layout, it doesn't look like pins 1 and 5 are connected to anything.
Scott
Coriolis
PostPosted: Tue Oct 24, 2006 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hm, guess you're right about that. I actually looked at that, and thought I was seeing jumpers between pin 1<>8 and 4<>5, but now I see it's actually part of the silkscreen... Embarassed
Gotta learn not to post when I'm tired... Rolling Eyes
Thanks for pointing that out!
C
