S/H => bitcrusher-style
Page 3 of 4 [84 Posts]
modularkomplex
PostPosted: Sat Mar 03, 2007 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did a simple LF398-version of the circuit. Works fine.
Mike
 Filesize:  76.74 KB
 Viewed:  1236 Time(s)
 Filesize:  94.71 KB
 Viewed:  928 Time(s)
Last edited by modularkomplex on Wed Sep 05, 2007 10:42 am; edited 2 times in total
bugbrand
PostPosted: Sun Mar 04, 2007 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice work! Well done & thanks for posting!
I'd been wondering on doing one with the LF398 - its edge triggered, right? So no need to make the trigger signal into a really narrow pulse..
http://www.bugbrand.co.uk
modularkomplex
PostPosted: Sun Mar 04, 2007 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, no need of a narrow pulse here. And the other difference is the need of a hold-cap - the 100nF between the ICs. This should be much smaller than the stated 100nF, I think 0.1-10nF would perform better. I still have to do some experiments here.
Mike
PS: I've tested various values for the hold-cap. Best audible results are with 4,7nF. 1nF and lower will result in a whistling background-sound (but that could be from the used NPO - had no foil-caps left at these values). I've updated the above posted pictures.
PostPosted: Sun Mar 04, 2007 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Mike this is great!! Thanks very much for posting these and,
welcome to electro-music.com too of course! Very Happy Very Happy Very Happy
ACHTUNG!
Photon
PostPosted: Thu May 10, 2007 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just stumbled across this:
The Malgorithm, a voltage-controlled bit depth and sample-rate reducer module.
http://www.youtube.com/watch?v=ZMxmxuA4LZg
website here:
http://www.theharvestman.org/
he's got two other modules finished as well, the "zorlon cannon"- pitched noise and gates, and the "hertz donut", a digital oscillator
really cool sounding stuff and worth a look Very Happy Very Happy
bugbrand
PostPosted: Mon May 14, 2007 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I 2nd the Worth-a-look view -- the Harvetman stuff looks really great & exciting. Mighty interesting & forward thinking.
bigtex
PostPosted: Sun Jul 22, 2007 7:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I woke up this morning with an idea in my head. I've finally solved a problem that has been bugging me ever since this thread started.
For a long time I've been wanting to make an effect with continuously variable amplitude quantization, but I hadn't come up with a good way of doing it that didn't involve analog to digital to analog conversion. A sample and hold works great for time quantization (sampling) but doesn't do anything to reproduce the effects of bit depth (aka "bitcrusher").
The problem with fixed bit depths is that you get fixed steps of amplitude quantization. 4-bit audio has 16 amplitude steps, and changing to 3-bit or 5-bit will jump to a different number of steps and a different sound. Wouldn't it be nice to smoothly scale the staircase to dial in just the right sound or slowly modulate the quantization?
The solution: comparators and two sample and hold stages!
This operates very much like a ramp-compare ADC but without the need for precision timing. The basic principle is that a sawtooth wave at a very high frequency is used as the reference input to a comparator, so every time the input audio and the sawtooth cross each other, the comparator changes state. This state change is used to drive the S&H chip's clock input (and National's LF398 is edge triggered, as pointed out before).
OK, so now we have audio being sampled every time it crosses paths with a high frequency sawtooth wave. Great. But that's no better than a regular S&H other than the slight skew between successive samples due to the sawtooth-wave based triggering. How does this get me adjustable amplitude quantization?
Add another stage before this where the sawtooth wave is, itself, quantized by an even higher frequency square wave. So if the sawtooth being used to quantize the audio was 10kHz (slightly audible ringing would be produced) then that sawtooth should be quantized by a, let's say, 100kHz square wave using another S&H chip. Now the 10kHz sawtooth is divided into a ladder. Turn the 100kHz wave up or down in frequency and you get a different number of steps.
Now that we have a staircase wave, let's go back to the audio being quantized. As I said before, every time the audio and sawtooth wave cross each other, a sample is taken. Now that we have a staircase wave instead of a sawtooth, each of those samples will be taken at specific amplitudes defined by the shape of the staircase wave.
Adjusting the square wave will change how many steps the sawtooth wave is divided into. Adjusting the sawtooth wave's frequency will change how frequently the input audio is divided into steps.
Smooth, infinitely adjustable quantization with variable amplitude steps and sampling rate. Just what I've always wanted.
SUMMARY:
Use existing S&H circuit to quantize a sawtooth wave.
Feed that into one input of a comparator.
Feed desired input audio into a buffer.
Feed first buffer output into second S&H chip.
Feed second buffer output into other input of comparator.
Use comparator output as clock of second S&H chip.
Enjoy the output greatly.
Any questions? (working on schematic and diagrams, here)
Edit: perhaps, depending on the speed of the ICs in use, it would be better for the 2nd S&H to sample the staircase wave instead of the audio input, just to be sure that the amplitude is correct and not dependent on the S&H grabbing the input audio at the right time...
bugbrand
PostPosted: Wed Jul 25, 2007 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Tex
(..I'm surprised no one else has commented on this exciting development!?)
Sounds ACE!
I don't fully understand your methods quite yet, but think I have an inkling what you're on about.
Let us know how yr investigations go!
PostPosted: Thu Jul 26, 2007 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I have been following this "exciting developement", and I'd love to comment on it, but unfortunately I have no idea what you're talking about! Laughing
Seriously though, I'm sure I'd get it if I just had the time to sit down and soak it up, (maybe the schematic will help), but with a head full of Klee and a lab full of bits, I just can't see the forrest for the trees at the moment. Confused Sad
trent saburo
PostPosted: Fri Jul 27, 2007 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
big tex is my hero
goodrevdoc
PostPosted: Fri Jul 27, 2007 9:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow BigTex, that's pretty cool. Not sure I can say if I can see the trees or the forest, but I think I have a very rude crude idea of what's going on. Bug's circuit already has a spot planned in my modular, and I've some 398's on the way. Got to say I really like these off the beaten path modules, makes my noodling time more interesting, IMHO.
-justin
bigtex
PostPosted: Mon Jul 30, 2007 3:23 am    Post subject: Reply with quote  Mark this post and the followings unread
After drawing some waveforms and thinking about it I've tweaked the design a bit. Now I use three sample & hold ICs.
I just spent the last three hours drawing out lovely diagrams of how this works complete with really detailed waveforms and explanation and then stupid Adobe Illustrator crashes during the save and wipes out the file. Great.
OK, instead I've attached a really awful photo of a poorly drawn block diagram. I guess I'll just try a little better to explain this time. Oh, who am I kidding this still won't make sense.
There are four input signals:
- sawtooth wave
- square wave (same frequency as sawtooth)
- clock (also a square wave, much higher frequency)
- audio input that you wish to quanitze
It all starts with a sawtooth wave. This is quantized by the first S&H chip and turned from a ramp shape into a staircase shape at a rate determined by the clock.
That same original sawtooth wave is also fed into a comparator. It is compared to the audio input. Every time the comparator's state changes (caused by the sawtooth wave or audio input becoming higher or lower than the other) the second S&H samples the current step of the staircase wave.
The third S&H is to make sure that there is only one sampled step per each cycle of the sawtooth wave. Depending on the S&H being used, this might need to go through some kind of divide-by-2 so that there will be one square edge to trigger the S&H per sawtooth cycle.
Too bad my waveform diagrams are gone because they really made all of this make sense. Grr I'm going to bed.
really basic block diagram
 Filesize:  149.9 KB
 Viewed:  31023 Time(s)
iorobyy
PostPosted: Fri Sep 21, 2007 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
hi!
where i could buy some AD781? (better a european source)
loss1234
PostPosted: Sun Apr 20, 2008 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
has anyone gotten this to work with the 398? i tried a long while back and it didnt work...i just wanted to know if lots of people have gone the 398 route and if there might be a press n peel layout??
if not, anyone know the best US place to by the AD chip??
thanks
synthmonger
PostPosted: Wed Aug 27, 2008 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
How bad does the oscillator bleed through for you guys? Theres alot of crackly noise that fades in and out on certain settings, it's kind of annoying ;x
I'm using a maxim charge pump and powering the board with +/- 9volts so I'm not sure if this has anything to do with it. I can't test it out on a bipolar 12 volt till I get home from work ;X Do you think this is the problemo?
synthmonger
PostPosted: Thu Aug 28, 2008 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
nm fixed it dang wire poped out of the board. I need to get my eyes checked Cool
noisedeputy
PostPosted: Sun Nov 16, 2008 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
etc....
what ever happened this development?
bigtex
PostPosted: Sun Nov 16, 2008 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
noisedeputy wrote:
etc....
Like just about everything in my life not related to my current job: nothing.
Sad but true. Since writing that my employment has taken over almost all of my time. I haven't even finished assembling all of the Blacet kits I bought over two years ago, let alone breadboard anything form my languishing idea notebook.
*sigh*
noisedeputy
PostPosted: Sun Nov 16, 2008 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
that's no fun to hear, let us know if you ever eventually get to work on this idea again then I suppose. Smile
softfin
PostPosted: Sat Feb 07, 2009 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok. I just have to break the silence in this topic Exclamation
I had a fully stuffed 398-version of the Bug Crusher laying on the table for at least a year, but today I finally wired it up and ... cheeeezeeey Works great. It sounds nice and dirty as expected.
There's a constant ringing sound going on which is audible with a low level signal and when there is nothing connected to the input. I suppose it is normal in this circuit(?)
Anyway, I find this a very useful module for various things. Thanks a lot to Tom for the design (and modularkomplex for the stripboard layout)!
bugbrand
PostPosted: Sun Feb 08, 2009 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Great stuff!
You should be able to decrease any background clocking noise by narrowing the trigger pulses (though I don't know particularly with the 398 'cos it maybe does things internally unlike the AD781).
Hey - and remember that you may also be able to set things just slightly differently and use it as a standard Sample & Hold module (ie running at low freqs).
Edit - also note that you should be careful with the wiring -- bad wiring can mean crosstalk which could be where your bad-tone-bleeds are coming from.
synthmonger
PostPosted: Tue Feb 17, 2009 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Tom you might wanna try using the 40106 vco I posted in the Lunetta thread as your main clock source for this circuit. Works pretty good!
rumpofsteelskin
PostPosted: Wed Jun 17, 2009 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Has this been abandoned?? I was toying around with it but noticed two problems -
- Changing the sample rate also changes the amount of quantization levels; lower sample rate = more amplitude levels. This could be sorted by phase locking the square wave to the sawtooth wave.
- The speed of the square/pulse wave looks to be prohibitively fast. Say if you want maximum resolution at 20KHz, then a minimum of 40K sawtooth wave to sample it with, and then assuming that 14bits is the maximum fidelity bit depth, that means 2^14 = 16384 possible amplitude levels. Which means the square wave clock must be at minimum 166384x40000 = 655MHz. This must also be variable to give the lowest resolution at the lowest frequency, say 30Hz. 30x2x2 = 120Hz.
Unfortunately, this doesn't look feasible which is quite a shame, the idea of it is pretty clever.
I think probably the only way to do the amplitude quantization is digitally...
does anyone know how the frostwave sonic annihilator works??
rumpofsteelskin
PostPosted: Wed Jun 17, 2009 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
*sonic alienator, rather...
rosch
PostPosted: Tue Mar 16, 2010 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi guys!
i have built modularkomplex's LF398 based rate reducer today (from page 3 of this topic).
i have one issue here. there's a very audible cv, almost as loud as the audio signal. when i turn the pot the pitch of the noise goes all the way up/down.
the effect itself works fine on the audio signal (edit: at least seems so).
i played bass through it and could turn the rate down (1M pot) so much that it sounded detuned (edit: with the cv i guess) and got pitch modulated. but i must have made a mistake so the cv comes through...
any idea what i could have done wrong here?
thanks!
edit: just created a new thread here
