slo
Joined: Feb 18, 2007 Posts: 204 Location: Victoria, BC
Posted: Mon May 07, 2007 7:15 pm Post subject:
Jacks on Foniks Modules |
I have been checking the modules you built on your great website, what jacks do you use? |
etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
Posted: Mon May 07, 2007 10:33 pm Post subject:
Aren't they sockets from Cliff? |
Posted: Tue May 08, 2007 3:10 am Post subject:
indeed, these are cliff sockets.
i made these layouts for my own needs so be aware of the spacing between the sockets: i use a 20mm spacing, not 20.32mm (0.8inch) - why? it's the hamburger royal story: it's because the metric system (my brain is trained on that). _________________
Tech Buddy at Random*Source |
fluxmonkey
Posted: Tue May 08, 2007 7:42 am Post subject:
anybody know of a source for these in the US? |
vc-zazou
Posted: Fri May 11, 2007 7:42 am Post subject:
Hi there
So i am planning to buy 100 of these cliff sockets.(for my two sequencers...)
Tell me fonik, where did you source them? in europe?
Farnell don't seems to sell them....
at the very least : hole spacing is about 8 mm am i right?
cheers |
Posted: Fri May 11, 2007 1:27 pm Post subject:
vc-zazou wrote: | Tell me fonik, where did you source them? in europe?
Farnell don't seems to sell them.... |
i once got a larger number of these from a fellow from the s-diy list. but you can allways order a larger quantity from cliff uk. don't know what the minimum would be.
Quote: | hole spacing is about 8 mm am i right? |
you are right. _________________
vc-zazou
Posted: Sat May 12, 2007 5:02 am Post subject:
thanks
at the very very least : how much is the thickness of your (wonderful) panels?? 2 mm ? 3mm ?
cheers |
Posted: Sat May 12, 2007 6:21 am Post subject:
vc-zazou wrote: | thanks
cheers |
i found that 1.5mm is fairly enough for 3U panels. before you bend them you'd broke the sockets or potentiometers, i guess. _________________
bearblock
Posted: Mon May 14, 2007 12:05 pm Post subject:
i use cliff jacks in my DIY modules too. I get mine from 'rapid electronics':
link
if you need loads though it might be cheaper to go direct. |
Dave Kendall
Posted: Sat May 26, 2007 3:47 am Post subject:
Hi Guys.
Thought it's about time I de-lurked......
Cliff UK will sell direct, and do the CL13841 sockets as a minimum order of 1000. Works out at £273-ish excluding VAT and delivery. This is the model that will take just about any 3.5mm plug.
The CL1384 is the regular model, is a bit cheaper, and has a minimum order of 200.
Cliff are out of stock of the CL13841 because apparently a German Modular synth manufacturer just bought up all the stock.
Now I wonder who that might be.........
Good to be here
Dave |
Posted: Sat May 26, 2007 3:00 pm Post subject:
hi dave,
good to have you here!
