 Forum index » News... » Gear News
System Design Calculator
seraph
Editor
Editor
Audio files: 31
PostPosted: Mon Jun 21, 2004 9:13 am    Post subject: System Design Calculator Reply with quote  Mark this post and the followings unread
SDC is a all inclusive program designed to act as a reference tool for the proffesional Sound Engineer or Designer. Conveinently engineered to run simply as an EXCEL application, SDC takes up Virtually no hardrive space or valuable memory. so... while you are running your SMAART, XTA, or Soundweb software you can easily reference it without risking your computers stability. The small size also lends it's self concviently to run on your Palm Pilot. Now you have a quick reference guide on you at all times.
http://www.downstagedesigns.com/SDC.html
mps board
