3rd run of PCBs for the PS3100 Resonators & the X-panfader
Page 5 of 14 [342 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, ..., 12, 13, 14 Next
PostPosted: Mon Jan 26, 2009 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
TekniK wrote:
Matthias,how does the VC has been implemented on the panner?
symmetrical,asymmetrical and what are the voltages?
Regards
the board basicly contains 4 differential pair based VCA with linear response.
i am not quite sure about the term (a)symmetrical. i fear i know what you mean. since the VCAs response to positive CV, and two of the VCAs are fed by inverted CVs without any offset, there is alway a attenuation of the signal during the fade.
in the context of the PS3100 it doesn't matter at all, since there is always the center channel present. you may recognize the effect more clearly, when only left and right input are used. rehear the soundsamples, you will recognize what i mean. as said before, the x-panner is an extension board in first degree. however, you can decide based on the soundsamples yourself.
hope that helps.
fonitronik at
TekniK
PostPosted: Mon Jan 26, 2009 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank u for your reply Matthias,its all clear.
PostPosted: Thu Jan 29, 2009 5:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi all,
i am not finished with updating the list with advance orders, sorry.
however, today i got aware that the german postal service changed their prices for international mails. they became a little bit undescent lately, i'd say. so i have to change the pricing for international shipping according to the new circumstances.
if you don't feel comfortable with it and want to change you advance order, don't hesitate to contact me again.
PRICING:
(under the assumption of minimum advance orders for 50 PCB each):
PS3100 PCB 13.-USD/10.-EUR
X-Panner PCB 10.-USD/7.50EUR
+ packaging & postage
1 PCB 4.-USD, more than 1 PCB 8.-USD worldwide
3.- EUR europe
2.- EUR deutschland
fonitronik at
machine.cuisine
PostPosted: Thu Jan 29, 2009 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fonik, I would like 1 Resonator PCB and 2 X-panfader PCBs.
(I believe I already requested one of each PCB - but I would like to update)
Smile
LektroiD
PostPosted: Thu Jan 29, 2009 8:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
To reiterate, my order is for one of each (1x reso / 1x panner). When you're ready can you invoice me the total with shipping to the UK.
Many thanks Smile
My tunes available here
(check out the new Electro-Funk LP)
numbertalk
PostPosted: Thu Jan 29, 2009 8:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik
Just to confirm I'm still in for 2 Resonator boards and 4 Panner boards.
ericcoleridge
PostPosted: Fri Jan 30, 2009 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd like 4 X-Panner PCBs please. Final answer.
Thanks Fonik.
asafnetzer
PostPosted: Sat Jan 31, 2009 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
If I haven't written it yet, I'm in for 1 Reso and 2 X-Panner Boards.
Thanks
lexvortex
PostPosted: Sat Jan 31, 2009 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik,
I'd be interested in one or two panner/fader boards depending on how much panel space they take up. From what I can tell is there are two inputs and two outputs, plus mono out, plus a CV in and a pot to manual control the pan/fade, is that correct?
Thanks,
julianw
PostPosted: Sun Feb 01, 2009 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik,
If its not too late, I'd like to order 1 x Resonator PCB and 1 x panfader PCB.
Thanks
PostPosted: Sun Feb 01, 2009 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
not too late. there is no deadline yet.
fonitronik at
PostPosted: Mon Feb 02, 2009 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
the X-panner board provides following I/Os
    - 3(!) audio inputs (left, center, right)
    - 2 audio outputs (left, right - the mono output is from the resonators)
    - 1 potentiometer (manual spread)
    - 2 CV inputs (one with on/off switch)
    - 2 connectors for the PS3100 resonators (power and audio)
hope that helps.
i did not plan to do this PCBs almost at the same time as the TH SCM, therefor the documentation is not finished yet. sorry.
[edited for clarity]
fonitronik at
sandyb
PostPosted: Mon Feb 02, 2009 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
hi Fonik
i'd like 2 of each board please Smile
sandy
koura
PostPosted: Mon Feb 02, 2009 12:32 pm    Post subject: me too Reply with quote  Mark this post and the followings unread
Fonik,
I am down for 2 boards of each design.
I'm in the US. brian at koura dot us
thank you,
b.
astroschnautzer
PostPosted: Tue Feb 03, 2009 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
I would be down for 1 reso and 1 panning x-fade board.
lexvortex
PostPosted: Tue Feb 03, 2009 8:35 pm    Post subject: 1st attempt at the panner panel Reply with quote  Mark this post and the followings unread
Here is my first version of a 1U MOTM panel for the panner/fader.
 Filesize:  18.76 KB
 Viewed:  90 Time(s)
Panner.fpd
 Filename:  Panner.fpd
 Filesize:  2.39 KB
 Downloaded:  63 Time(s)
dave_3283
PostPosted: Fri Feb 06, 2009 7:39 am    Post subject: +2 3100s Reply with quote  Mark this post and the followings unread
I would like 2 3100 PCBs, please.
Thanks-
dave
LektroiD
PostPosted: Sat Feb 07, 2009 7:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, I realised I made a mistake on my requirements, I would like 2x panner and 1x resonator, if this is possible. Thanks Smile
wmonk
Audio files: 12
PostPosted: Sun Feb 08, 2009 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Fonik,
1 resonator and 1 panner for me Smile
Thank you,
Wmonk
Danno Gee Ray
PostPosted: Sun Feb 08, 2009 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I would like to be in for 1 Panner and 1 Resonator.
Thank you
PostPosted: Mon Feb 09, 2009 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
i am taking advance orders until 27 FEB 09, then the files will be sent to the manufacturer - i will order some spares, though.
i will PM everyone concerning payment as soon as the PCBs arrived at my door. BTW everyone who placed an order whould have received a PM by now.
some of you already ordered TH SCM PCBs. in these cases i could hold the SCM PCBs until the PS3100/panner PCBs are in to send them together, thus saving you some postage -and causing me some logistic nightmare Laughing . however i would have to call for seperate payment for the SCM PCBs when they are in: it has not been my plan to do these PCBs in that timely manner in the first place, just because of all the upfront payment i have to do. somehow it just happened. Very Happy
send me a PM if you want to have it this way, please.
fonitronik at
bugfight
PostPosted: Mon Feb 09, 2009 10:22 am    Post subject: Reply with quote  Mark this post and the followings unread
i'd like 2 of each, please.
and you can send them with the scm if it's not too nightmarish...
crashlander42
PostPosted: Mon Feb 09, 2009 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
One of each. I think. There's a strong temptation to get two panners, but I'm short on cash and keep talking myself out of it.
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
droffset
PostPosted: Tue Feb 10, 2009 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
One of each for me please. Smile
henrikgo
PostPosted: Wed Feb 11, 2009 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
One of each please!
