 Forum index » electro-music.com » Help
Attachments in PM
Page 1 of 1 [16 Posts]
TekniK
PostPosted: Thu Apr 29, 2010 11:23 am    Post subject: Attachments in PM Reply with quote  Mark this post and the followings unread
I can't UL attachments in PM anymore,gets error that attachment limit is reached but there is none in my sendbox or outbox,the counter is at 0 in fact!
Audio files: 116
G2 patch files: 317
PostPosted: Thu Apr 29, 2010 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yup, I cant see any for you either .. how about the recipient?
TekniK
PostPosted: Thu Apr 29, 2010 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
everything is empty of attachments
Audio files: 116
G2 patch files: 317
PostPosted: Thu Apr 29, 2010 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
The recipient being the one you send a PM to ... does that person have room left for PM attachments?
TekniK
PostPosted: Thu Apr 29, 2010 2:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did tryed to send already to different ppl.
The error message says its my UL that has reached its limit
TekniK
PostPosted: Thu Apr 29, 2010 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tryed to send u a attachment Blue Hell,but no luck
 Filesize:  65.85 KB
 Viewed:  109 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Thu Apr 29, 2010 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, thank you, I will try to look into it.
Audio files: 116
G2 patch files: 317
PostPosted: Thu Apr 29, 2010 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, one more question, how big was the attachment?
TekniK
PostPosted: Thu Apr 29, 2010 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
i can't send the attachment,look the screenshot
TekniK
PostPosted: Thu Apr 29, 2010 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
54.8KB
Audio files: 116
G2 patch files: 317
PostPosted: Thu Apr 29, 2010 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, that should just work, yup.
Audio files: 116
G2 patch files: 317
PostPosted: Thu Apr 29, 2010 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had a look in the database ... not sure if I did the correct things .. but it looks like PM attachments do not get properly cleared from the databse ... maybe ... or maybe it does not quite work as I had expected it to work ...
Does the following list of attachments look familiar to you?
Code:
vcs_motm_traces_161revised_591.pdf
vcs_motm_traces_120r_476.pdf
mc_8_e_208.pdf
mc_8_134.pdf
mc_8_man_102.pdf
TekniK
PostPosted: Fri Apr 30, 2010 12:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Code:
mc_8_e_208.pdf
mc_8_134.pdf
mc_8_man_102.pdf
Hi,yes they are from me ,but sooo old,in fact u can delete everything linked to my profile,if thats help
Audio files: 116
G2 patch files: 317
PostPosted: Fri Apr 30, 2010 12:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I cant just delete them ... as that would corrupt the database ... working on it, but this may take some time.
Audio files: 116
G2 patch files: 317
PostPosted: Sun May 09, 2010 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I've changed something, could you try again?
Sorry for the delay, but needed some info that I could not get earlier.
TekniK
PostPosted: Tue May 18, 2010 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
No worries,i did use a file server meanwhile,seems it works now again.
Thank u very much Jan!
Niio1
