Posted: Tue Jun 26, 2012 5:46 am Post subject:
I'll add the stripboard layouts ASAP. _________________ What makes a space ours, is what we put there, and what we do there. |
tony void
Posted: Tue Jun 26, 2012 6:55 am Post subject:
Exciting piece! I've yet to build my own spring reverb but I've played around with amplified springs in the past using mallets, bows, glass slides, etc. fx pedals as well. Very inspiring work Unkle!! Those mp3s rock too!
-void |
Posted: Wed Jun 27, 2012 5:29 am Post subject:
I've done a couple of mods, and the quality keeps getting better.
I swapped out the 500KLin feedback pot for a 1MLog one. This is much better! With feedback set to "0", I can get the Volume and Drive controls up around the 70% before I start to get a high pitched ringing, and a sudden increase in noise level.
But,.... because I can drive the speaker harder, without uncontrolled feedback, I'm getting more signal induced in the coil. I can then bring the feedback up, just to the point of extended decay.
I also cut a further 5 turns off the spring, and soldered it to the top (piezo) hook. (It was just hanging there before) Then I noticed a lump of solder on the lower connection, between two spring turns. It was sitting up enough to touch the turn above it, but not actually holding it mechanically. By re-soldering it and solidifying the bond, under tension, I've killed the spring chatter by 80-90%, depending on how hard you drive the speaker. So the chatter is still an optional mode, but it doesn't dominate the "working" area of Volume settings.
Anyway,....
Here's a new sample.
This time I'm taking a left and right out of the DR202 (all internal effects off), and sending one side through the ReVibe. So you can hear the original sonic quality which is going in fully right, and the line out level from the ReVibe fully left.
I'm gonna do a spectrum analysis of both sides later, but you can see right away, if you open it up in Soundforge etc, the two waves going by. The relevance seems pretty reasonable, and you can clearly see the initial delay of the spring.
First off all three controls are at 9 o'clock, after the raw test I bring the drive control up for a couple of bars, then back to 9 o'clock and I start bringing the feedback up slowly. After a bit of feedback stuff, I play with the main volume control. Then I start "playing" the structure.
Sorry it's so long and repetitive. Just mucking around. Could be a good sample in there somewhere!
Description: |
Download |
Filename: |
ReVibe Stereo 27-6-12b.mp3 |
Filesize: |
7.23 MB |
Downloaded: |
1102 Time(s) |
Posted: Wed Jun 27, 2012 6:34 am Post subject:
I've just found out that when I save as an .mp3 out of Soundforge, the left and right channels contaminate each other quite severely.
Has anyone else found this? _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Wed Jun 27, 2012 7:25 am Post subject:
Looks I've got a dodgy mp3 encoder. It's fine if I pull back from 320Kb/s to 256Kb/s. Strange hey?
Anyway, I'll do this test again later. The one I posted is at least partially separated, and it's kinda fun anyway. _________________ What makes a space ours, is what we put there, and what we do there. |
dougseidel
Posted: Wed Jun 27, 2012 4:23 pm Post subject:
I just thought I'd add that when you do listen to the properly separated sample, the repetition of the drums and bass give a better idea of what the ReVibe is doing over time.
The bass promotes a deep rumbling which slowly follows the bassline and is big, but quite cool. With a lowpass filter, and dropped in volume, it would make a nice deep wash behind any low frequency sound.
Also, I've noticed that the hi-hat sometimes sounds like it's going through a flanger. I s'pose this is due to the high frequencies getting a relatively short delay as they first hit the spring. It comes and goes, depending on what other vibrations have been set up already, and is quite unpredictable. This is exactly the kind of stuff I was hoping for, as these complex interactions in the physically of the unit would be very hard to simulate in other ways. _________________ What makes a space ours, is what we put there, and what we do there. |
JingleJoe
Posted: Sat Jun 30, 2012 9:40 am Post subject:
Regarding making it better, just had a look at your schematic, did you try wiring up the feedback pot as a voltage divider? I'd try making a passive mixer, for the lm386 input, mixing the input and feedback via pots wired as voltage dividers. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Green Dungeon Alchemist Laboratories |
SineHacker
Joined: Mar 09, 2010 Posts: 99 Location: United Kingdom
Posted: Mon Jul 02, 2012 2:54 am Post subject:
hey, I am working on a crude spring reverb, I just started a thread, but I think I will move the conversation over here as you have got a bit further. I am using an LM386 setup similar to yours (I am using a schematic from the datasheet - the one with bass boost but with a few caps substituted as this sounded great with classical guitar with a piezo pickup on the body). I used a 4049 circuit for the piezo pickup from Nicolas Collins designs (can't find a schematic to quickly link to, but I will post one if you are interested) which works a treat with a little high end roll off.
I am trying to get feedback working as well in hope that this will extend the reverberation a little. I'm going to try out some of the stuff you have here but i'm not using any transistors in my setup - I have some 2n3819, do you think they might work the same as yours, at least on the amp side?
As for the self-oscillation rumble, I was getting that as well even without trying to add a feedback route, but I found this was a lot to do with excess wire on the lm386 side, or wire passing over wire and things, I guess when I solder it up some shielding might be in order.
SineHacker
Posted: Mon Jul 02, 2012 4:32 am Post subject:
well I didn't find need for transistors after some tests, the 2n3819's were just dropping signal for me in the same configuration as above, admittedly I don't know much about them!
I used a 100uf supply filter cap (this is what decoupling is, right?) like JingleJoe suggested here: http://electro-music.com/forum/topic-54234.html and from the original schematic on this thread, and that has worked a treat on cleaning up the input signal, thanks!
I am in two minds over how to finish it at the moment. If I use two batteries and two circuits then I get a perfect "wet" signal, but can't get any feedback. If I use a single battery and join the circuits then I get a lot of the dry signal spilling into the wet, and it also starts picking up radio frequencies! but I can get feedback using a similar configuration to Uncle Krunkus
feedback isn't actually extending the reverb at all but it does sound cool
I was wondering if there was a compact way I could drive four smaller speakers, where the first speaker carries the input signal from an instrument down one spring and then the next three are driven by piezos - I'm guessing I would need four amps to do this but it might still be a nice compact solution for a longer reverb. |
Posted: Mon Jul 02, 2012 4:45 am Post subject:
Wow dude!
Love that construction!
I never even thought of adding more than one string and pickup. And yes, I reckon driver into pickup into driver * 4 sounds the bomb!
You could even experiment with cross springing the four springs. (You know those really tiny elastic springs you can get out of old tape decks?)
Oh what a tangled web we weave!!
Seriously though, mine has way too much bottom end, I had to put that big cap across the driver to calm down the endless rumbles. Then again, you are using thinner springs, and I'm not sure how much tension they're under. May be a better (different?) set of vibration frequencies altogether.
This is why I wanted to see what others came up with.
BTW, I'd love a copy of that 4049 pickup. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Mon Jul 02, 2012 4:54 am Post subject:
I like the larger box idea dude. But I must admit that I'd go for solid wood once you get to that size. The plastic will just send way too much dry signal direct to the piezo/s. You want to minimise that mechanical coupling as much as possible.
You've got me thinking now of a solid wooden cabinet. Possibly built out of old fence palings.(These are the cheapest hardwood around! ) With boards either end, mounted on that 1" squidgy rubber stuff you can get from Clark Rubber (Aus) One board contains the 3-4 drivers, one contains the 3-4 pickups.
You could even have rotary switches on the stereo outputs, to select which output you're monitoring.
Possibly even selective feedback!!
Oh man,...... this is gonna happen! _________________ What makes a space ours, is what we put there, and what we do there. |
SineHacker
Posted: Mon Jul 02, 2012 5:54 am Post subject:
Yeah, i didn't test it too much for plastic feedback! I kinda presumed it would be a problem hence the sponge padding - this however does very little as tapping on the box is way louder than anything the springs can really produce!!
I just did some recording and used some headphones in the process which has made me change a couple of things;In the end I decided that actually the difference between having the circuits linked or separate is so minor that it probably doesn't matter. I took out the top end roll-off from the pick up section as well, this is controlled by a small cap and I found it was actually a bit extreme, so I think I will find a cap that has a lower effect and add a switch as well.
I tried the feedback again with the circuits running from one supply, listening with headphones I found it sounded a lot better than I thought and does seem to affect the tail to an extent before it goes into oscillation, I did record this but Logic balls'd it up somehow
this recording shows the sound first with two separate circuits and then with them linked together (recorded with a homemade mic, the noise at the end was caused by me)
http://soundcloud.com/aidantaylor/reverb-test
I will draw up a schematic for the 4049 pick up now |
SineHacker
Posted: Mon Jul 02, 2012 6:11 am Post subject:
just as a note, adding a really small cap in parallel with the pot will give you the high-end roll off, the larger the cap, the more roll off. Like in your schematic, I used a 100uf cap to decouple the lm386 side and a 220uf cap for the 4049 side when using a single battery |
Posted: Mon Jul 02, 2012 6:17 am Post subject:
Sounds really nice dude! _________________ What makes a space ours, is what we put there, and what we do there. |
SineHacker
Posted: Mon Jul 02, 2012 6:19 am Post subject:
the springs are pretty loose in mine, my original idea was to have each at different tensions with the idea that you would get a fuller range in the reverb, but it was a bit difficult with the tools and materials I had at home so I just ended up glueing it together!
I'm gonna try soldering mine up with the feedback loop now - I think further revisions can go in the next model! |
SineHacker
Posted: Mon Jul 02, 2012 12:14 pm Post subject:
I made so many mistakes when soldering that I am surprised it actually worked in the end!! I got all the pots back to front as well
had a play and it sounds nice but it's not very versatile - mine also turned out to be bass heavy as hell, when I tested it earlier today from the breadboard I didn't pick up on that, nor in the recordings I used my own adaption of the "bass boost" in the lm386 datasheet thinking it would improve the tinny sound of piezo's, but it probably isn't necessary at all here!
You know you were saying about putting a capacitor across the speaker terminals, I realised I had done a similar thing earlier on by putting a 100k resistor from the speaker output on the board to ground (I think again this is a suggestion in the lm386 datasheet and I tried it to reduce rumble) so I just soldered it across the speaker terminals in the end.
Still picking up a lot of radio traffic I'm gonna try to shield the boards when I next have a go at this I think |
JingleJoe
Posted: Mon Jul 02, 2012 2:23 pm Post subject:
Sheilding your wires will stop you picking up more radio traffic You can get some nice little wires with stranded sheilding, especially for audio applications like this, out of old tape players _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Posted: Mon Jul 02, 2012 2:31 pm Post subject:
I'd definitely lose the 100K across the speaker and replace it with a 47uF bi-polar cap. This will help with the bottom end. The 100K resistor wouldn't do anything helpful at all AFAIK. _________________ What makes a space ours, is what we put there, and what we do there. |
ANNILOG
Posted: Tue Aug 13, 2013 2:27 am Post subject:
The ReVibe Subject description: Worth a read |
Hi All
Looking for information on spring reverb I came across this
http://www.electronicpeasant.com/projects/thermio/thermio.html
With 300v from the transformer this is NOT circuit bending but the background information is useful
Brian |
SineHacker
