A Question... Not so much asked.
Page 1 of 1 [6 Posts]
tiptaptempo
G2 patch files: 16
PostPosted: Fri Sep 28, 2012 10:55 am    Post subject: A Question... Not so much asked. Reply with quote  Mark this post and the followings unread
Hej Guys,
Maybe a silly question, but hard to find the answer alone.
How can i transcribe this (from 3/27 to the end) ?
http://www.youtube.com/watch?v=njJaMb1e50I&playnext=1&list=PLAA2ECBDE6C2C9378&feature=results_main
If you watch and listen carefully, you can see that the first part of the video is : one hit of the tom = one change of bass drum and snare drum sequence.
At the end, from 3/27 to the end, when he hits his tom, you can listen the octave of the bass drum + the melodia from his snare.
BUT when he hits his snare dum, he sounds like a normal snare, no notes.
I was thinking about a Clk Gen linked to all y snare sequencers / or logic gates.
Ideas ?
reg
tiptaptempo
G2 patch files: 16
PostPosted: Sun Sep 30, 2012 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
It's like i've full of sequencers note in all y slots, and sometimes i would like that some of these play twice.
So in a "live" situation, it's like only one element can play two sequencers at the time, and not one like i already do.
Where is the trick ?
Sorry for the english
Reg
Roland Kuit
G2 patch files: 125
PostPosted: Sun Sep 30, 2012 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
H Tip Tap,
Here is a patch which can bring you further.
Here the Sequencers are triggered by a clock module. You can trigger these by the audio in triggers mentioned before. The 3rd sequencer makes the switch.
 Filesize:  63.75 KB
 Viewed:  1182 Time(s)
Sequencer change.pch2
 Filename:  Sequencer change.pch2
 Filesize:  2.1 KB
 Downloaded:  129 Time(s)
Roland Kuit
http://rolandkuit.com/
tiptaptempo
G2 patch files: 16
PostPosted: Mon Oct 01, 2012 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeaahhh !
I moved the clk gen and put the audio in trigger discussed before, works fine.
I've just put into the fx area some sequencers. So into the VA there is the famous octaves, and in fx area the main theme of the song. Such this way it's working.
I tried to put more seq.
How now can i chain these sequencers to have more with this way of controlling ? Every time i try i don't see that.
BTW, my g2 is working again, the usb port has been removed and a new one is coming, 40 euros. Knock on wood now.
And i must admit that even if this synth is a f...... hard level, i have A LOT of fun when i play drums with. It's really like video games.
One hit final.pch2
 Filename:  One hit final.pch2
 Filesize:  3.17 KB
 Downloaded:  108 Time(s)
Roland Kuit
G2 patch files: 125
PostPosted: Mon Oct 01, 2012 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
All those questions Tip Tap.
You have my book. Just read the chapter Dance-Techno II for chaining Sequencers. 3rd patch!
Roland Kuit
Roland Kuit
G2 patch files: 125
PostPosted: Mon Oct 01, 2012 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
And nice, your patch Smile
Roland Kuit
mps board
