Joined: Jan 07, 2009 Posts: 1196 Location: Scottish Borders
Audio files: 155
Wobuse
Audio files: 155
Posted: Sun Jun 02, 2013 4:56 am Post subject:
thanks
It would be nice to do a full keyboard but i need it to fit under 2 modular cases in a corner, so it has to be a sloped front, wedge shaped sound module only.
thanks for the links tho.
Dave. |
Audio files: 155
Posted: Sun Jun 02, 2013 9:34 am Post subject:
Been in the shed......
I sketched out the design of plywood box to fit in the small space under the ASM-2 synth, then into the shed armed with saw , measuring tape , set square & straight edge & pencil ,pva wood glue , bag of 1" brads / panel pins & hammer. Oh , and nice plywood off cuts from a work skip .
After a couple of swearing incidents and a tea break and this is what i hacked together today.
Description: |
Filesize: |
159.58 KB |
Viewed: |
710 Time(s) |
Description: |
Filesize: |
149.74 KB |
Viewed: |
636 Time(s) |
Description: |
Filesize: |
177.91 KB |
Viewed: |
750 Time(s) |
Description: |
Filesize: |
159.39 KB |
Viewed: |
654 Time(s) |
Posted: Sun Jun 02, 2013 6:10 pm Post subject:
Are you very short? I'm just trying to figure out how you got footprints inside the box!
Audio files: 155
Posted: Mon Jun 03, 2013 12:00 pm Post subject:
My Nord micro mod. done a protest dance in the box when i wasn't looking |
Audio files: 155
Audio files: 155
Audio files: 155
Audio files: 705
Audio files: 155
Posted: Sat Jul 06, 2013 10:47 am Post subject:
pink panther |
Audio files: 155
Posted: Sat Jul 06, 2013 10:50 am Post subject:
yes , i like the lilac / purple colour , but the orange is super easy to read the text , but i'll learn it real quick , looking like purple if the print shop has some
Dave. |
Audio files: 705
Audio files: 155
Posted: Sat Jul 06, 2013 11:50 am Post subject:
Fantastic , heh , thanks Phobos |
Audio files: 155
Posted: Sun Jul 14, 2013 7:30 am Post subject:
Hi ,
The 6 lfo's i have made on veroboard are from Ray's site under the oldies but goodies section , six of the "variable skew lfo" which outputs 3 main waves... sine / ramp - tri - saw (skew) / square.
I have made a few veroboard circuits and i now just follow the diagram and populate and isolate as i go and give it a good continuity test afterwards before the "no chip" power up test.
I have also started to the mfos micro S & H circuit which will have the lockhart wave folder & dividers on the same strip.
more in a week or so
Description: |
Filesize: |
176.32 KB |
Viewed: |
479 Time(s) |
Description: |
Filesize: |
188.25 KB |
Viewed: |
458 Time(s) |
Description: |
Filesize: |
139.23 KB |
Viewed: |
424 Time(s) |
ashleym
Posted: Mon Sep 02, 2013 12:34 pm Post subject:
Sorry to be late on this.
What filters are you going to use? I like a variation from the standard LPF. A SVF or a combined LP/HP such as the MOTM CS80, Ian Fritz Threeler? I have a CGS CMOS or Wasp style filter on the drawing board. Mine will have dual-concentric pots to control two filters from one(ish) set of controls. I got these from Small Bear. _________________ http://soundcloud.com/for-mash-get-ash |
Audio files: 155
Posted: Fri Sep 06, 2013 9:56 am Post subject:
Hi Ashleym
I have a mfos lowpass for vcf1 and a mfos state variable for vcf2 that are to be taken from the modular .
cool , dual pots is a good idea , hope to see pics of your twin vcf your building / planning.
On my filter section, im going for a toggle switch to choose between normal independant vcf CV control or vcf1 CV in sum to vcf2 cv in, so they can both be sweeped from vcf1 cutoff dial. (whooooosh! sounds and more )
Dave. |
Audio files: 155
Posted: Fri Sep 06, 2013 10:21 am Post subject:
Im slowly taking my time with this build , heh , ive rearranged the panel layout a bit to fit the FX i wanted on the panel, which is now 600mm long , still in the final stage of "what can i put in that space" , i was thinking vc-panner or a externally clocked melodic/random trigger generator of some sort for the 4 ADSR's. Hmmm.
Description: |
Filesize: |
530.11 KB |
Viewed: |
480 Time(s) |
Description: |
Filesize: |
97.2 KB |
Viewed: |
513 Time(s) |
Audio files: 705
Audio files: 155
Posted: Fri Sep 06, 2013 10:39 am Post subject:
Hi Phobos , yes it's in there , hiding on vco2 and a lockhart wavefolder on vco1 , wavey |
Audio files: 705
ashleym
ashleym
Audio files: 155
Posted: Wed Sep 11, 2013 10:13 am Post subject:
Hi Ash
Nice blue panel , i like blue
Mad idea.... ignore this if you have finalised the design...... a double pole switch to swap one of the filters sweep direction on the dual pot , half way turn on the dual pot would be the cross-over point of the 2 filters sweeps.
Dave. |
Audio files: 155
Posted: Wed Sep 11, 2013 10:26 am Post subject:
I was scanning over the layout and it dawned on me i'd forgotten glide/ portamento on the vco's , fixed now , i've considered a few circuits for the space at the right end of the panel and i think im drawn to ken stones burst generator circuit for a bit of spicey trigger action on the ADSR's & probly through an attenuator to the vco cv in's as well.
Finish the panel design , then off to the print shop up town for a black n white drill template sticker and the finishing final 250mm x 600mm lilac / purple vinyl sticker with black text lazered on.
Dave. |
