Nord Lead 2x without internal voltage switch?!
Page 1 of 1 [4 Posts]
moogoogle
PostPosted: Mon Sep 09, 2013 9:30 am    Post subject: Nord Lead 2x without internal voltage switch?! Reply with quote  Mark this post and the followings unread
Hello, I'm importing a Nord lead 2x from Japan to Australia. The vendor has informed me that the transformer is regulated at 100v for the specific Nord Lead 2x model which is manufactured for usage in Japan only and does not have a voltage switch for usage under 220v. Can someone confirm if such models were ever manufactured? From my knowledge all Lead 2x models have a voltage switch for the power supply, pls advise if this is the case.
MANY THANKS!!!!
Audio files: 213
G2 patch files: 319
PostPosted: Mon Sep 09, 2013 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi moogoogle - I'd ask Clavia ...
moogoogle
PostPosted: Mon Sep 09, 2013 8:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wrote to them. Just thought someone might know! Cool
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Thu Sep 12, 2013 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you sure it is a NordLead2X? Have you seen the instrument?
NordLead(1) and NordModular Classic (dating before 1998) were build without a switch, but you could change by sodering different connections...
Wout
