nil
Posted: Sat Feb 04, 2006 11:22 am Post subject:
Testing The OSC's and filters |
I am buying a used Andromeda. I wanted to know what to test for when i get the unit so here are a couple questions.
1. Do i test each oscillator and see if it is in the range of +/- 4 cents?
2. Why do i have to test the filters/vca? How do i actually test this? (I read sunny's post ,but it was really confusing and i dont know what he was trying to say in there).
3. Is there anything else i should test for when i get this unit? |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
nil
Posted: Sun Feb 05, 2006 1:27 am Post subject:
Re: Testing The OSC's and filters |
| nil wrote: | I am buying a used Andromeda. I wanted to know what to test for when i get the unit so here are a couple questions.
Questions 2 and 3 still weren't answered |
ian-s
Joined: Apr 01, 2004 Posts: 2518 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 584
Posted: Sun Feb 05, 2006 1:44 am Post subject:
| nil wrote: | | Questions 2 and 3 still weren't answered |
2.
Sounds to me Sunny is warning that there are dodgy chips in some of these units, so it may test fine pre-purchase but become unusable after a short time (and require expensive repairs).
3.
Just play the thing, try as many presets as you can, if your happy with the sound and are not put off by its 'software plugin' looks or potential maintenance issues, buy it. |
nil
Posted: Sun Feb 05, 2006 2:54 am Post subject:
How can filters go bad?
If a filter goes bad can i hear it?
Also is there tunings for filters? If so do i have to make sure these tune as well? |
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Posted: Sun Feb 05, 2006 8:41 pm Post subject:
always check the best-before-date of filters.... _________________ Spiral Recordings |
ian-s
Audio files: 42
G2 patch files: 584
Posted: Sun Feb 05, 2006 10:50 pm Post subject:
| paul e. wrote: | | always check the best-before-date of filters.... |
Analog filters can self oscillate at high resonance settings, producing a sine wave. So they should be able to track the keyboard. Probably dont require the same range and accuracy as a VCO though.
Unless it is oscillating, variations in the filters will just mean that some notes sound different to others, like softer, brighter etc. This is part of the charm of real analog but in the worst case, it can make the machine unplayable. |
nickelodeus
Posted: Tue Feb 07, 2006 4:37 pm Post subject:
Ahh I always wondered what the self-oscillating filters meant. A couple of additional questions....
1) is this ability ever useful....ie used in the world of synth programming to produce a certain charactaristic?
2) How do i get my a6 to do this to hear the effect ?
thanks
nic |
Joined: Apr 03, 2004 Posts: 19598 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Tue Feb 07, 2006 5:02 pm Post subject:
| nickelodeus wrote: |
As an extra oscillator, or some say it makes a better sine wave than their main osc.
| Quote: |
By turningup the filter Q until it resonates. Got no details for the synth in question, but on a digital filter some very low level noise may be needed at the filter input in order to give the filter something to resonate on.
[/quote] _________________ Jan |
Tim Kleinert
Joined: Mar 12, 2004 Posts: 990 Location: Zürich, Switzerland
Audio files: 6
G2 patch files: 201
Posted: Wed Feb 08, 2006 2:39 am Post subject:
When the unit is well warmed up and tuned, the Andros filters track the keyboard perfectly over the entire range. (Well done, Alesis!)
Oscillators generate a sine wave output by using the triangle output with some additional waveshaping. Hence it is never 100% pure. For a 100% pure sine wave (given that the signal path isn't clipping), self-oscillating filters are used with preference. _________________
nickelodeus
Posted: Thu Feb 09, 2006 4:03 am Post subject:
Hey Guys....thankyou for your responses!
You'll have to forgive me but I'm trying to learn more about synthesis so I can start making my own sounds from nothing ...not just altering existing patches!!
Is it ok to ask a couple more questions? .....sorry if this is basic stuff
1) I am right in thinking that filter Q is the same as resonance?
2) If I were to get the filter to self oscillate....do I keep the cutoff low or high? Also, if I used the filter as an oscillator could i then use the oscillator to do something interesting to the sound?
3)What does it mean when ou say that the filters track the keyboard perfectly on the a6?
Thanks guys
nic |
Audio files: 107
Posted: Thu Feb 09, 2006 7:34 am Post subject:
Q is the same as resonance.
When we say the something tracks the keyboard it means that the pitches of the modules follow the pitches on the keyboard. Essentially, this means the instrument plays in tune.
When you crank up the resonance and the filter starts oscillating, then the cutoff works like the frequency knob on an oscillator. Cutoff should really be "cutoff frequency". _________________ --Howard
my music and other stuff |
ian-s
Audio files: 42
G2 patch files: 584
Posted: Thu Feb 09, 2006 10:51 am Post subject:
| nickelodeus wrote: | Also, if I used the filter as an oscillator could i then use the oscillator to do something interesting to the sound?
You would probably be able to modulate the filter frequency with one or both the oscillators, giving bell/metallic type sounds. The filter ADSR is also available to bend these sounds.
Careful adjustment of the resonance around the onset of oscillation, can give interesting effects as the filter and oscillator frequencies interact. |
nil
Posted: Fri Feb 10, 2006 6:53 pm Post subject:
I just got my andromeda...i really like this thing..it was off of ebay so im just making sure it's in good shape....
i tuned it and was cheking tuning....it's never exactly the note i play it fluctuates...........how much should it fluctuate by?
i think sunny said +-4 cents...would this be correct? |
Audio files: 107
Posted: Fri Feb 10, 2006 9:57 pm Post subject:
Might be best to send Sunny a PM if someone who actually owns an A6 doesn't answer.
Congrats on the new synth. I hope you enjoy it. I think they are great instruments. _________________ --Howard
Audio files: 116
G2 patch files: 317
Posted: Sat Feb 11, 2006 6:18 am Post subject:
| nil wrote: | | ...it's never exactly the note i play it fluctuates |
Just in case: be sure to have all frequency modulation on oscillators off. |
sunny pedaal
Joined: Nov 16, 2004 Posts: 651 Location: netherlands
Audio files: 12
Posted: Sat Feb 11, 2006 7:45 am Post subject:
| nil wrote: |
yes,
make sure you warmed her up sufficiently ( 15 minutes should do ) to make life easier keep temptuning and maybe also background tuning on. take the default patch and keep the modwheel off and also switch of the oscilator and filter modulations. try testing b.e. first only osc1 and thereafter all osc's 2( voice assign to rotate and watch the voices playing under global-> vox monitor)
now +-4cent should be reasonable for this analog synth . when some voices are too much out of tune you might try it again after tuning that seperate voice only by when in vox monitor mode switching off the other voices and then pressing osc freq tune ( under tune).
more than 4 cents deviation start becoming annoying as they cause too audible beatings, some slow drifting ( about or less than 4cents) is ( on this synth) inherent to analog i guess and makes it even more lifely.
afcourse your tuner should be good enough to detect the difference , mostly they are accurate within +-1cent , some older guitar tuners however only within +-3cents, (very good ones go up to 1/100 cent), you have to watch for that in the specs of your tuner and afcourse add it to the acceptable deviation of +-4cents.
also check the filters once, the same procedure exept that you'll switch off the oscilars and with filter two turn up the resonance fully, with a keytracking of 50. tune the middle A and thereafter measure it over the keyboard. however most known problems occur due to improper osc chips. when filters break down mostly it can easily be heard because of some clear distortion b.e.
congratualations with the synth when in good shape it's a cracker!
fr. gr. sunny |
bentropy
Joined: Oct 19, 2006 Posts: 2 Location: san francisco CA USA
Posted: Thu Oct 19, 2006 4:56 pm Post subject:
Andromeda owner seeks help diagnosing issues Subject description: possible defects on my new (used) andromeda? |
I just got a used Andromeda off of Ebay, from a seller who is only giving me 3 days to return it if something is wrong. I didn't realize these things were so temperamental and inconsistent in quality, or I wouldn't have bid.
So now I'm trying to perform diagnostics.
I don't have a tuner handy now, but here's what I've done:
I've tried to follow Sunny's guidelines, posted on Sat Feb 11, 2006 2:45 pm
- performed an autotune after the machine has warmed up,
- turned off all the LFOs and modulators I think might affect pitch, that I know how to,
- with both oscillators on, played a single note, in slow overlapping repetition.
What I hear worries me: on some notes, the two oscillators play in quite close unison, but on almost every other note I hit and hold, I hear beating from tuning differences between them, esp noticible in upper octaves. Is this indicative of the bad oscillator chips?
Sunny has referred to 'b.e.' What does this mean ? Before envelope?
Also, a separate issue is that the aftertouch seems strange to me. If I assign it to, say, an oscillator's pitch, and map a range for the values, there is a very narrow range of pressure to pass through the in-between values. Mostly it sounds binary, with an un-pressured state and a pressured one, rather than continuous depending on how hard I press.
I hope I'm not screwed. I think the seller would be difficult or impossible to send this back to and get my ~$1700.
hope I've been clear, thanks a lot,
Ben |
sunny pedaal
Audio files: 12
Posted: Fri Oct 20, 2006 1:26 am Post subject:
b.e. means "by example"
the aftertouch isn't the most super one , as long as it works on all keys , it should be oke, you can eventually tune it more to your likenings a bit later.
the beating of the oscillators could be more of a problem.
to find out this first remember that a slight bit of beating could be normal as long as:
the beating isn't too fast in frequency, once every few seconds ( once in five seconds is as good as they can get i guess) should be oke in the higher frequencies. a few times every second is too much.
you could , after warming up test every voice apart and monitor them by mon vox. then when you know which voices are best and which are worst retry tuning the oscillators with the good voices turned off. when they are in the normal range switch it of and proceed.
in the end they should all be in the "normal" range as described above, and thus all voices should have been turned off as they have passed the test.( this might take you at least 5 times or more passing the test)
if one or more voices can't be tuned within the normal range , if ba.e. one voices beatings really remains to keep happening a few times every second, you probably have a not so good chip for that voice and it should be switched off or replaced. ( this offcourse in not too extreme settings so put the osc to 440 hz and test over the 5 octaves, not transposing the keyboard).
the a6 is not perfect but it should be a reasonable enough analog synth.
after all for 1700$ you almost could also find another a6 when needed.
let us get a notice on the results you found so we might discussed them further.
fr.gr. sunny[/b] |
sunny pedaal
Audio files: 12
Posted: Fri Oct 20, 2006 1:36 am Post subject:
one thing more : after warming up and tuning it by autotune , might be an idea to "restore tuning tables"
do this by restarting while holding down softbutton ...., ?i thought number two under the screen , however have to find the manual again to find out exactly. if you have one manual yourself just look that one up and try it also before going on testing. |
