Breath Controlling the Andromeda with a Steiner EVI
Page 1 of 1 [2 Posts]
Infrablue
PostPosted: Mon Jan 30, 2012 6:39 pm    Post subject: Breath Controlling the Andromeda with a Steiner EVI Reply with quote  Mark this post and the followings unread
Some real time playing around with CV input using a Steiner EVI as a breath control source. Notes and pitch bend played on Andromeda's keyboard.
All the modulation of volume, tone and filters are done in real time with the breath control through CV input by normal blowing as well as humming with my own voice into the EVI, multi tonguing and pallet fluttering into the EVI. Sound its self is from the Andromeda VCO's etc.
A Yamaha BC can do this stuff as well but it would need to be converted to CV instead of midi.
The playing is a little clumsy and also exaggerated to show the modulation... For most of the patches here, I usually like less resonance on a melodic line but these demonstrate the CV quite well.
Near the last half the resonance and growling grow progressively more extreme for demonstration. There are about 4 different patches throughout.
I was up all night excitedly playing around with the CV input... glad I finally got around to trying it! So happy to finally get breath control going on an Andromeda!
And here are a few tracks from about 17 years ago with melodies done on that same EVI using it's own analog sound module to compare. (Initial flute sound is EVI playing VL70-m module in a duet with an analog EVI square wave.)
Infrablue
PostPosted: Mon Feb 20, 2012 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a schematic, which includes circuit for the Yamaha BC-1 (bottom left of image). Converting this output to CV would give the A6 the ideal wind control with analog resolution.
Yamaha CS-01 Overall Circuit Diagram.pdf
 Filename:  Yamaha CS-01 Overall Circuit Diagram.pdf
 Filesize:  303.96 KB
 Downloaded:  321 Time(s)
