New to Aurdino: Idea's for project?
Page 1 of 1 [12 Posts]
stolenfat
PostPosted: Wed Apr 04, 2018 11:55 am    Post subject: New to Aurdino: Idea's for project? Reply with quote  Mark this post and the followings unread
Hey Guys,
Been messing with logic CMOS (lunetta) based noise makers for years (I love them dearly) and now I'm considering getting into ardiuno. Any one have any suggestions for a project for me to look into?
I love wild noises with lots of varied textures, soft and harsh. I like unpredictability, ala circuit bending, but some control is nice too.
Any suggestions or directions for me to check out?
Audio files: 20
PostPosted: Wed Apr 04, 2018 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Check my signature, its an all arduino synth
my synth
stolenfat
PostPosted: Sun Apr 08, 2018 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't want to poo poo your work, cause it is awesome (and well played btw- very cool stuff on your channel)... BUT it is fairly similar to many things I've seen done with other/usual modular synth designs...
I guess I was hoping for a link to a completely outlandish noise maker using arduino. Something that sets it apart from using typical chips due to a digital (code) advantage.
electrotech
PostPosted: Sun Apr 08, 2018 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Have a look at this :- https://bleeplabs.com/store/nebulophone/
I made a DIY version for a pal of mine and we both think it sounds amazing.
Mainly stripboard
 Filesize:  561.7 KB
 Viewed:  7 Time(s)
stolenfat
PostPosted: Tue Apr 10, 2018 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
very cool, thanks for the share.
stolenfat
PostPosted: Sun Apr 15, 2018 2:17 am    Post subject: Reply with quote  Mark this post and the followings unread
quick question: if I was to send a clock signal from my lunetta which i typically run at 9v in my case... in order for that to work with arduino at 5v should i connect my clk input jack to a voltage regulator or should i just use an adequate resistor to bring it down?
electrotech
PostPosted: Sun Apr 15, 2018 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Since the Arduino inputs are at high impedance and very little current is drawn, you just need to drop the signal voltage from 9V to 5V using two resistors in series which forms a potential divider. Try 18k and 22k with the bottom end going to 0V (GND) and the junction to the Arduino.
Andy
Audio files: 20
PostPosted: Sun Apr 15, 2018 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Or use a zener diode (4v7) with a resistor of ~10k
my synth
stolenfat
PostPosted: Sun Apr 15, 2018 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the clarification mates. I'll bust out my multimeter and see what I get when I get started.
Audio files: 20
PostPosted: Sun Apr 15, 2018 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
In fact, you could leave out the zener and just use a resistor, because of the input configuration of the (Atmel) processor itself.
See: http://electro-music.com/forum/topic-68022.html
my synth
stolenfat
PostPosted: Tue Apr 17, 2018 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm pretty sure I understand what your saying... so i doodled up a quick ms paint just to make sure. Set up connections like in this pictogram right?
All I gotta do is find the proper values.
-Cal
 Filesize:  9.91 KB
 Viewed:  1 Time(s)
Audio files: 20
PostPosted: Tue Apr 17, 2018 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
if you are going from a lunatta output to an arduino input, just connect a 10kohm resistor between the two, the input circuit of the arduino does the rest.
my synth
