Virtual Analog Synthesizer
Page 3 of 3 [62 Posts]
Goto page: Previous 1, 2, 3
VA1
PostPosted: Sun Sep 02, 2018 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
2MB program, 1MB delay, nice reverbs possible.
Is the audio dac in this board build in ?,
or do you have the DAC with wires in breadboard ?
and dont i need external audio crystal for specific samplerates like the DSPIC ?
i will order this board, only it is backorder for 17 weeks.
What software do i need to install for programming ?
is it fully free ?, with full optimizing ?
Wont it all run on winXP ?
JovianPyx
Audio files: 218
PostPosted: Sun Sep 02, 2018 9:16 am    Post subject: Reply with quote  Mark this post and the followings unread
The whole point of the Nucleo boards is low cost minimal function. They have Ethernet, but that's about it. So there's no DAC or CODEC on the board. The other option is something like a discovery board, but that's a lot more expensive and will likely have a CODEC, but also other things you may not want.
The SAI interface provides a bit clock for I2S if the CODEC is put into slave mode. I'm not sure if it always needs a crystal or not, so when you select a CODEC or DAC make sure to check the datasheet to know if you need xtal or not.
The currently supported programmer software is STM32CubeProgrammer which is free. You should go to the ST site and browse around, there's all manner of stuff there and their software is all free, including STM32CubeMX (a CPU chip configurator) and the "library" of interface functions for the STM32 internal devices. The free "library" is not precompiled and is supplied as C source code so you can include it as is or modify it for special needs.
Oh - I don't believe so, especially not the 32 bit version. ST-LINK might work, but the Cube programs may not work. I gave up on XP when my Pentium 4 HT machine crapped out and i've been running WIndows 7 ever since on a new machine (the old hardware would no longer boot).
Depending on what you use for OS, there is more than one way to do compiles. There are several pay-for IDEs, but for free, I think there's an Eclipse based IDE that runs under Windows (possibly even XP). I don't compile in Windows, though I do use Windows to run the free device programmer (STM32CubeProgrammer). For edit and compile of source code, I've been using Fedora 27 and gcc properly set up to compile for STM32 CPUs. In my case, I have a file server that both Windows and Fedora can see, so it's easy to do the compile and edit under Fedora and the programming under Windows. In my lab, Fedora 27 runs as a VirtualBox VM under Windows 7.
You'll need to do research on compilers for your own needs and desires.
Time flies like a banana.
corruptio optimi pessima
VA1
PostPosted: Sun Sep 02, 2018 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok i will download the STM32CubeProgrammer in 17 weeks, i cant wait.
Now i am looking to making PCBs in china, that cost very much for a very small print.
What is the cheapest and good pcb farmer ?
VA1
PostPosted: Sat Sep 15, 2018 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I have to say the synthesizer is not that bad.
I throw in reverb and all is good.
With distortion the noise is minimal.
For with chorus the sound is to soft,
there is no CPU left, i have to make it louder somehow.
Why i made it so soft i dont know, maybe the IIR filters clipped, i have to boost it somehow without clip.
Very good synth with reverb.
You dont especially need a juno or tb303, this synth can replace in your track.
Very playable
JovianPyx
Audio files: 218
PostPosted: Sat Sep 15, 2018 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe someone else can help with this, I don't make PC boards.
VA1
PostPosted: Thu Sep 20, 2018 4:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I have the nucleo with worlds most powerfull chip, thanks jovian
VA1
PostPosted: Wed Oct 03, 2018 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Now more volume, less noise.
VA1
PostPosted: Sat Oct 06, 2018 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Another update
VA1 v0.41.zip
 Filename:  VA1 v0.41.zip
 Filesize:  165.83 KB
 Downloaded:  110 Time(s)
VA1
PostPosted: Sun Oct 14, 2018 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I tuned the oscillator to run at 44,65 MHz.
It seems the noise is worse then before now with more high tones.
I guess running this chip at lower clockspeed will have also less noise then, intresting.
JovianPyx
Audio files: 218
PostPosted: Mon Oct 15, 2018 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Isn't that overclocking the dsPIC? If so, I wouldn't expect it to run properly.
VA1
PostPosted: Mon Oct 15, 2018 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I used the internal oscillator finetuning to get almost 12% extra power.
Anyways i got the phaser running and can not go back.
Adjusted baud rate generator from 79 to 88.
JovianPyx
Audio files: 218
PostPosted: Mon Oct 15, 2018 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
I understand what you did, but the internal electronics of the chip are not guaranteed to run faster than 40 MHz. Above 40 MHz, yes, it can appear to work. However, it cannot be guaranteed to work correctly and consistently at speeds above 40 MHz. That is likely why you are experiencing the noise. Also when overclocking any CPU, the actual attainable reliable and error free speed will vary from unit to unit. If I need more speed than the dsPIC provides, a different CPU would be my choice. One issue is that other people trying to do the same thing may not be successful.
