 Forum index » Clavia Nord Modular » G2 Performances - Completed
Metamorphosis
Page 1 of 1 [10 Posts]
sheridan
Audio files: 27
PostPosted: Sat Jun 17, 2006 6:56 pm    Post subject: Metamorphosis
Subject description: Funky acid trance - 9+ minute .mp3 attached
Hi.
Not much to say really... here's something I've been working on recently. My first experiment with 'semi-random' generated music. I can see I've still got lots to learn about making it sound less random, but I'm quite impressed with it myself. Embarassed It's kind of like some weird improvised acid jazz trance bouncy house, or something like that.
I've used a modified version of my Drum machine patch (attached here: http://electro-music.com/forum/topic-7037.html)... a really handy patch!
Anyway, the variations in the song go on and on, so the .mp3 example is quite long... sorry if you're still using a dial up connection.
Have fun Very Happy
<<Edited>> Once I found out this patch wouldn't work on an unexpanded G2, I went back to work, filling up unused DSP. I have attached the new updated performance in this post. I have also attached a longer version .mp3 for any unexpanded G2 users interested in hearing more of the performance and a shorter version for those using a dial up connection.
Metamorphosis example.mp3
.mp3 example of the attached Metamorphosis performance. Bouncy acid trance, or something like that. 4:23 - 3MB
 Filename:  Metamorphosis example.mp3
 Filesize:  3.01 MB
 Downloaded:  414 Time(s)
Metamorphosis long example.mp3
longer .mp3 example of the attached Metamorphosis performance. Bouncy acid trance, or something like that. 9:48 - 6.72MB
 Filename:  Metamorphosis long example.mp3
 Filesize:  6.72 MB
 Downloaded:  376 Time(s)
Metamorphosis - Sheridan.prf2
Metamorphosis.prf2 - Never ending improvised acid jazz trance bouncy house, or something like that.
 Filename:  Metamorphosis - Sheridan.prf2
 Filesize:  30.6 KB
 Downloaded:  815 Time(s)
transformer Sheridan
G2 patch files: 584
PostPosted: Sat Jun 17, 2006 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Expanded only Sad
Amazing work, mp3 sounds great.
sheridan
Audio files: 27
PostPosted: Sun Jun 18, 2006 5:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh sorry, I thought unexpanded G2s might be able to get 1 voice out of each slot... just as well the .mp3 is a reasonable length.
cebec
G2 patch files: 31
PostPosted: Sun Jun 18, 2006 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is really good, man! Cool
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Mon Jun 19, 2006 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I can't play the perf, but the mp3 sounds really cool. Are you just letting that run? Or are you tweaking as it plays?
Audio files: 107
PostPosted: Mon Jun 19, 2006 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Super... I like this. thumb up
sheridan
Audio files: 27
PostPosted: Mon Jun 19, 2006 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys Very Happy
Just recorded it as is... the different sounds have different playing time cycles, so they come and go and every so often they link up, ie. hats, kick and bass cuts together. They could be set to more irregular settings to randomise it further, but... meh. Also variations in note probability are controlled by LFO's, some global, others solo, so it also sounds different depending when you press run. No tweaking needed. Very Happy
Ivity
G2 patch files: 57
PostPosted: Mon Jun 19, 2006 10:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wooow Shocked , that's soo cool, incredible work! Very Happy
Igor
www.myspace.com/phoiod
www.bl-project.com/Ivity.html
mother misty
G2 patch files: 130
PostPosted: Thu Jun 22, 2006 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great sheridan!
Stuff like this should be included in the factory library
sheridan
Audio files: 27
PostPosted: Fri Jan 12, 2007 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just loaded this track up to remind myself what it sounded like. Now I have to admit that I have been e-mailing and browsing, ie. not solely listening to the music, but it took about 40 minutes before I realised that I had just been listening to the same performance! Very Happy
In fact, that was probably 10 or 15 minutes ago and it's still playing. Very Happy I suppose the point I'm trying to make is that... er... well... you can listen to this performance for ages and not hear the same tunes/patterns. Hah... you could probably just leave it on all night as background music. Laughing
Niio1
