Noob working out Klee build for the Bridechamber front panel
Page 1 of 1 [6 Posts]
sync24
PostPosted: Wed Jan 06, 2010 3:35 pm    Post subject: Noob working out Klee build for the Bridechamber front panel Reply with quote  Mark this post and the followings unread
hello,
I'll just start by saying thanks for the electro-music Klee Sequencer, I'm finding everything surrounding it very inspiring!!!
Ok, I've been getting stuck-in to attempting to understand as much as I think I need to get through building this.
The only prior experience of doing this sort of thing before is building a MFOS WSG kit and digging around online to work out how to build an atari punk console.
What I'm trying to get my head around at the moment are the optional features in relation to the Bridechamber front panel I have.
I've been searching the forum here for answers, but there's a couple I am still a little stuck with.
I may be jumping the gun a little as I probably don't fully understand the issue due to not having actually arrived at it in my build process.
So please do forgive me if I'm asking any really dumb questions, this is all pretty new to me!
Ok, so here I go...
First Q:
Optional Voltage Control Outputs - Output A, Output A+B and Output B and associated Glide controls.
In the Klee build issue 6 pdf it states the outputs are provided on J3 on the Analog Board through a 6 pin connector (P1).
Looking up J3 in the pdf, the 8 pins there appear to connect to the 9 thru 16 switches of the Gate Bus (P55 Fig 6-2).
Where is the 6 pin connector? Should it be J13 instead (P64 Fig6-17)?
Second Q:
Variable Range Control Options.
Regarding Option 1 - I'm going to stick a 150k in R33 (as mentioned >>here<<), that's fine.
When it comes to the other options, am I right in thinking that the Bridechamber panel is set up for Option 4 - EXT RANGE on the left of the panel is ready for a jack socket and switch, and I follow P38, Fig 4-16?
Third Q:
Optional External Load Enable Switch.
Same deal as prev Q really, panel is ready with EXT LOAD on the left waiting for a jack socket and switch, and I follow P36, Fig 4-13?
The last two options I think I'm cool with. I've got old Roland gear so have gone for the 5V gate and trigger option (the parts kit I got from here didn't have the 1k5 resistors though so I need to get some).
The Automated Range Switch Data Inputs I don't know what that means, so I'll leave on a high note!
Thanks in advance for help with this!
Duff
patchdub
PostPosted: Sun Jan 10, 2010 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi. i am almost finished wiring my klee with the bridechamber panel. whew! its alot of wires.
1 ?- yes j13
2 ?- yes option 4 on pg 38
3 ?- yes
hope this helps.
the only question i still have is how to wire the clock thru jack.
www.patchdub.com
sduck
PostPosted: Mon Jan 11, 2010 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
AFAIK the clock thru jack is just a straight connection to the clock in jack - basically it's just a small built in multiple. There's nothing on the pcb's that would connect to it, at least on the versions I have.
patchdub
PostPosted: Mon Jan 11, 2010 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks sduck!
all done wiring. tried so hard to keep it nice and tidy but at some point it just got out of hand
about to power up. fingers crossed!
 Filesize:  18.32 KB
 Viewed:  5376 Time(s)
www.patchdub.com
PostPosted: Tue Jan 12, 2010 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I included the "auto range control" links just in case anyone wanted to tap into the three bits which control the range and make them programmable or clockable from external sources etc. The default is to leave those links on the board and just wire the rotary as shown.
sync24
PostPosted: Fri Jan 15, 2010 1:16 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the replies peolpe!
i think i'm getting there with this build,
term started again this week though, so life is hectic again...
i'll no doubt be back with a couple more Qs soon,
thanks again!
duff
