Quadrature Oscillator
Tim Kleinert
G2 patch files: 236
PostPosted: Mon Mar 26, 2012 1:36 pm    Post subject: Quadrature Oscillator
Subject description: 0, 90, 180 and 270 outputs
After reading this thread, I thought I'd try another shot at quadrature oscillators.
This solution is simple, multiplexing a single PhaseOsc. The outputs are 48kHz, but the oscillator will respond faithfully to sync and exponential FM.
EDIT: I forgot to copy the patch to all variations. Be careful.
EDIT 2: I have to specify: If the response to expFM and sync should be 100% accurate, you'll have to downsample the FM or sync source down to 48k. This takes a mere S/H module clocked by the 48k clock which is already there (the feedbacked audiorate inverter module). Syncing to or modulating by blue signals works without this precaution, because these clock at 24k.
QuadratureOsc TK.pch2
0, 90, 180 and 270 degrees outputs
 Filename:  QuadratureOsc TK.pch2
 Filesize:  1021 Bytes
 Downloaded:  1263 Time(s)
G2 patch files: 625
PostPosted: Tue Mar 27, 2012 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great idea Tim
Works very well. Lots of possibilities.
iPassenger
G2 patch files: 78
PostPosted: Tue Mar 27, 2012 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh i get it, it is as if the FM causes the osc phase to be in two places at once but the sample and holds determine which location is listened to.. smart! Was looking at for ages wondering how it was doing it! Cheers. Smile Course this would work with lfos at the 24bit rate.
iP (Ross)
Tim Kleinert
G2 patch files: 236
PostPosted: Tue Mar 27, 2012 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers. Smile Multiplexing is your friend. The only limitation is the sample frequency you need at the outputs. I could wring 16 different phase outputs @ 12k from just one oscillator. In one of my granular patches, I squeezed 8 delay taps @48k out of a 4-tap delay. The G2 audio rate is quite high (96k), so multiplexing/downsampling is often a workable solution.
