  Muied Lumens Frequencies
G2Engine: Problems with NoteZone to drive a slot from Guitar
Page 1 of 1 [4 Posts]
Spawn-X
PostPosted: Wed Mar 06, 2013 6:48 pm    Post subject:  G2Engine: Problems with NoteZone to drive a slot from Guitar
Subject description: Guitar-To-MIDI problems.
P'tit lu all...
First, sorry for my bad english. Sad
I use a Roland VG-99 for both guitar modelisations and internal synths.
Now, I need to use the Guitar-To-MIDI function of VG-99 to drive Slot A (for example) on my Nord Modular G2 Engine.
This function have 2 modes: Mono or Poly.
First one turn my guitar into 6 MIDI channels. I just have to select the channel Number for the first E string. This MONO mode, is the only one that permit to drive different tones from diferent strings. For exemple, a Pad on strings 1 to 4 (e, B, G, D), and Bass Lead on strings 5 and 6 (A, E).
My problem is I couldn't find any way to keep this MONO Mode while I have to drive only one tone.
I tried to use the NoteZone module to filtering/routing each 6 MIDI Channels to one, but I fear I don't use it correctly or it has a bug.
My settings are like that:
NMG2E:
-Global Channel=1
-SlotA MIDI Channel=2
-SlotB MIDI Channel=3
-SlotC MIDI Channel=4
-SlotD MIDI Channel=5
Need to drive a simple patch on SlotA
MIDI-Guitar is set like that:
-String e send notes on MIDI Channel 2
-String B send notes on MIDI Channel 3
-String G send notes on MIDI Channel 4
-String D send notes on MIDI Channel 5
-String A send notes on MIDI Channel 6
-String E send notes on MIDI Channel 7
In my patch, I inserted 5 occurrences of NoteZone module setted like that:
NoteZone1: Rcv-Chan=3; Min=C-1; Max=G9; Send-Trans=0; Chan=2; LetThru=Note+Ctrls
NoteZone2: Rcv-Chan=4; Min=C-1; Max=G9; Send-Trans=0; Chan=2; LetThru=Note+Ctrls
NoteZone3: Rcv-Chan=5; Min=C-1; Max=G9; Send-Trans=0; Chan=2; LetThru=Note+Ctrls
NoteZone4: Rcv-Chan=6; Min=C-1; Max=G9; Send-Trans=0; Chan=2; LetThru=Note+Ctrls
NoteZone5: Rcv-Chan=7; Min=C-1; Max=G9; Send-Trans=0; Chan=2; LetThru=Note+Ctrls
f course, I just have sound while playing string "e" but nothing while plucked 5 other ones. Sad...
Can anybody help me please?
Thank you.
Sorry for my bad English. I'm French.
Spawn-X
PostPosted: Wed Mar 06, 2013 7:27 pm    Post subject: Re: G2Engine: Problems with NoteZone to drive a slot from Guitar
Pfff... Finally found the solution...
Send Chan must set to Slot A for each modules... Embarassed
PostPosted: Wed Mar 06, 2013 11:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad that you found a solution! I'd love to see your patch, if you'd like to attach it here in the thread! Of course, I'll understand if you don't want to share it.
Spawn-X
PostPosted: Thu Mar 07, 2013 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
No problemo for that, but please wait some weeks because I'm just exploring some ways about this duet "NMG2E/VG-99", and I haven't any interesting patches to share for the moment.
But, ASAP, be sure I'll share them. Wink
