LM13700 VCA and other circuits
Page 1 of 1 [9 Posts]
alkopop79
PostPosted: Sun May 12, 2013 9:46 am    Post subject: LM13700 VCA and other circuits Reply with quote  Mark this post and the followings unread
I wonder how should I modify the VCA circuit in the datasheet to work with 9V instead of +-15V. Needless to say, the OTA would get +-4.5V respectively. How do I change the reistor values? Any help would be appreciated!
 Filesize:  28.39 KB
 Viewed:  10610 Time(s)
richardc64
Audio files: 26
PostPosted: Mon May 13, 2013 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Forget that. Below is the VCA from "SynTom", a single-supply Percussion synth. The original supply was 12V. For 9V the resistors most likely to need adjusting are R32 and R33.
The signal input is reference to ground, and the low end of the output pot could connect to ground instead of 1/2V+.
 Filesize:  6.65 KB
 Viewed:  224 Time(s)
alkopop79
PostPosted: Mon May 27, 2013 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Eventually I've found a simple VCA that works fine at the Rockit Synth's blog:
http://hackmeopen.com/wp-content/uploads/2011/04/My-VCA.png
Thanks for the help!
alkopop79
PostPosted: Mon May 27, 2013 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Also, I've built a VCO circuit I've found in Ray Marston's article at Nuts&Volts:
http://www.nutsvolts.com/uploads/magazine_downloads/11/May%202003%20Ray%20Marston%20-%20Understanding%20And%20Using%20OTA%20OP-Amps.pdf
Page 10, Figure 19. square wave and triangle VCO[/url]
Instead of 30V (+-15) I used 9V (+-4.5V) and works just fine.
alkopop79
PostPosted: Mon May 27, 2013 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
The VCO circuit.
OTA VCO
 Filesize:  70.69 KB
 Viewed:  153 Time(s)
beep
PostPosted: Mon Jun 17, 2013 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://folkurban.com/Site/9VpoweredMS20SallenKeyLPVCF-690.html THIS IS REALLY COOOOL!
I built this today and finally got it working <3 I used 10k instead of 100k after cutoff cv, 100k limits the range too much
 Filesize:  6.89 KB
 Viewed:  10157 Time(s)
 Filesize:  6.89 KB
Is the future obsolete?
analog_backlash
Audio files: 21
PostPosted: Mon Jun 17, 2013 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've been playing "spot the difference" with your two schematics, but I've come to the conclusion that it's a double-post Very Happy . Anyway, it sounds really great. I've used this VCF in the past:
http://www.magicmess.co.uk/electronics/12dbfilter.php
I think that yours sounds better though. Also, I found that the BP signal was very weedy, so I added a single transistor amp on this output.
Gary
beep
PostPosted: Wed Jun 19, 2013 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
"it distorts in a bit yukky way, perhaps clippers there could tame that a bit"
clippers where? at the output?
L´Andratté
PostPosted: Wed Sep 18, 2013 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Put one (or 2/serial/antiparallel/si/ge/experiment) diode to ground between the resonance pot and the 680 pf.
Probably with switch.
