help with fruity loops 5
Page 1 of 1 [5 Posts]
qsue47
PostPosted: Fri Sep 22, 2006 5:52 am    Post subject: help with fruity loops 5 Reply with quote  Mark this post and the followings unread
hi everyone im new here. i was wondering if anyone could help me with my problem i have frity loops v5. when i first got it my playlist windo would move the pattern smoothly but now when i move the patterns they jump to a box instead of sliding smoothly. this has created major problems for me because some of my channel dont kick in when i want them to.
opg
PostPosted: Fri Sep 22, 2006 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you mean to say it is more of a computer glitch? Like the computer is struggling? Confused
I'm still using good old faithful Fruity Loops 3.5, even though I also have Fruity Loops Studio. I keep Studio because you can use it as a VSTi, otherwise, I found it to be a bit glitchy. However, I haven't read up on version 5 yet.
One Player Game | OPG on SoundCloud
Audio files: 228
PostPosted: Fri Sep 22, 2006 7:08 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome qsue47
Just want to say, hi. I don't use FL.
qsue47
PostPosted: Fri Sep 22, 2006 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks mosc. ok maybe i need to go into my problem with more detail. the playlist screen and also my piano roll keep acting up instead of the blocks o whatever they are called moving smoothly along the grid it jumps from box to box.
dj_tyme
PostPosted: Tue Oct 17, 2006 1:41 am    Post subject:  YOur problem Reply with quote  Mark this post and the followings unread
Well actually don't go throwin' out your computer yet. lol.... Fortunately, there's a very simple solution to that problem Smile
Looking at your Fruity Loops notice the CPU Square on the top-middle-rightish area. lol
U should see it.
Now.... Look under and you will see the word SNAP..right over that is a drop down menu on wich you need to click, and set to (none)
You see what happens is that when snap is on it snaps your notes to the grid in order to get a perfect kick line and what not..to get a good bpm...mainly for techno songs i suppose, but anyway...... turning it off will allow you to place your squares anywhere you like on the grid once again Smile
