<on air> Modulator ESP Adventures In Sound
 Forum index » How-tos
Intelligent MIDI Sequencing with Hamster Control
Page 1 of 1 [3 Posts]
PostPosted: Sat Feb 21, 2004 6:06 am    Post subject: Intelligent MIDI Sequencing with Hamster Control Reply with quote  Mark this post and the followings unread
http://www.nbb.cornell.edu/neurobio/land/STUDENTPROJ/2002to2003/lil2/
Abstract:
This project was initially fueled by the desire to explore the MIDI protocol. It was decided that this would be accomplished by building a MIDI device. I also aimed to make something novel that had never been done before. But to balance out the unusual nature of its design, I wanted to also to create something that was very musical.After much consideration of different technical design aspects and contemplating various musical ideas, I was able to arrive at a project that would fulfill all of my musical and engineering goals.An intelligent MIDI sequencer was designed with hamster control. The MIDI sequencer intelligently produced melodies by manipulating the musical elements of rhythm and note-choice. Guided by inputs based on hamster movements, Markov chains were used to perform such beat and note computations. In culmination, 3 simultaneous voices were produced spanning 3 octaves and 3 rhythmic tiers. Each voice was controlled by two hamsters: one that was responsible for adjusting the rhythmic qualities of the melody and another that modified the note sequence. With all of these elements in combination, an output was produced with very musical qualities.All of this was implemented using an Atmel Mega32 microcontroller, distance sensors, a HamsterMIDI Controller, and 6 hamsters. Embedded C programming implemented the algorithms and computations within the sequencer.Overall, this project was successful. The control between the hamsters and the musical intelligence turned out very well. The music sounds as good as I imagined, and I am very satisfied with the outcome of my design experience.
Flickr
Audio files: 232
PostPosted: Sat Feb 21, 2004 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I love this. thumright
For some reason, I couldn't get the movie to play, but he mp3 file is very cute. I can imaging hamsters moving back and forth as they compose this music.
egw
G2 patch files: 8
PostPosted: Sat Feb 21, 2004 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's important that the hamsters can hear the music.
So, in theory at least, they are playing the music, since they hear the results of their actions! Otherwise it is just a cute randomization method.
