wurfholz
Posted: Wed May 16, 2007 5:57 am Post subject:
Chuck performance/old machine |
Hi out there!
has anyone of you experience with ChucK on slow machines?
I´m trying to configure an old notebook to chuck around a little.
After i´ve managed compiling Chuck the machine seemed to be too slow.
Two of the otf_0*.ck examples work fine. Three shreds at the same time produce glitches and dirty noises and more produce silence.
Has anybody similar problems and solved it?
I tried the alsa- AND the jackd-Versions of chuck.
Thanx a lot
wurfholz
My Setup:
Hardware:
AMD K6II 350MHz
160 MB
System:
Debian Linux "ETCH"
Kernel: Standard 2.6-486 Kernel |
Posted: Wed May 16, 2007 7:09 am Post subject:
Hmmm, yes, that would be a bit slow.
You could look up the commands to the Virtual Machnie and increase "--bufsize" but I fear that won't help all *that* much if you already experience hickups after two otf files.
You can still render in non-real time but I fear you might need to bite the bullet and look into a new machine. On the bright side; computers that will deliver a LOT more performance are relatively affordable these days. _________________ Kassen |
chuckles
Joined: Apr 02, 2007 Posts: 72 Location: San Diego, California
Posted: Wed May 16, 2007 8:14 am Post subject:
Old machines... |
| I notice that wurfholz is in Germany, so it may be different there, but I know that in the US, most medium and large size corporations literally discard PCs that are not at least Pentium 4 class. A notebook/laptop might be a different story... |
wurfholz
Posted: Wed May 16, 2007 8:38 am Post subject:
yes, i know!
But it´s the only notebook i´ve got right now and i got it for free!
I´ve configured it for maximum speed (No useless deamons, no X-Servers etc.)
The only thing i could imagine to improve the power is to compile my own kernel, but i´ve never done that before....
maybe i should try a 2.4 Kernel... !??
Anyway thanks for the --bufsize hint. Will check that some time... Not right now! after two days oft trying to get chuck working properly i´ve got a little bit headache...
wurfholz |
nicolas3141
Joined: May 25, 2007 Posts: 185 Location: Christchurch, New Zealand
Posted: Fri May 25, 2007 2:13 am Post subject:
I have run chuck on a 400MHz Win98 machine without any problems, but not attempting anything too heavy duty.
Nicolas |
wurfholz
Posted: Fri May 25, 2007 5:07 am Post subject:
interesting. How many Memory do you have?
Could it be, that Win offers a more performantic environment to chuck than Linux?? |
Posted: Sun May 27, 2007 3:39 am Post subject:
It could be that win-ChucK is a bit more optimised then the Linux one at the moment. I also think that the Windows one uses a slightly larger buffer by default and by default it runs at a lower bit-rate (44K v.s. 48K). _________________ Kassen |
kijjaz
Joined: Sep 20, 2004 Posts: 765 Location: bangkok, thailand
Posted: Mon May 28, 2007 11:30 am Post subject:
one thing i usually do while playing around with ChucK on a slower laptop machine..
(especially Linux.. which is usually slower than Windows if on the same machine)
is that to lower the Sample Rate used for real-time use.
22050 is okay..
and sometimes i actually play at 8000 .. lol.
anyway that'd depend on the soundcard you're using if it can play the specified sample rate. |
wurfholz
Posted: Mon May 28, 2007 12:30 pm Post subject:
Yes i´ve tryed this too, but then i got errors from my Jack-Demon, which seems to expect a specified sample rate.
But maybe i can configure this within Jack.
Does anyone have XP with that issue?
Thanks for the usefull hint!
wurfholz |
