Zero Hertz FM
Page 1 of 1 [5 Posts]
Sotaru
G2 patch files: 5
PostPosted: Tue May 22, 2007 12:51 pm    Post subject: Zero Hertz FM Reply with quote  Mark this post and the followings unread
I found out about Zero hertz FM from the Modular tutorials, and read
through the old post:
http://electro-music.com/forum/viewtopic.php?highlight=zero+hertz&t=10742.
But I don't seem to get it. Sad
I made the attached patch and with some turntable scratching
it produces the enclosed sound.
But:
If the Oscillator has 0 Hertz, why is there a sound in the very
beginning? It can be clearly heard when the external modulation
signal comes in.
Shouldn't 0 hz be silence? Also the pitch is much higher
than I would expect it to be when I turn tha platter very slowly...
An idea anybody? Thanx!
Regards
Marc
zeroHertzFM.pch2
 Filename:  zeroHertzFM.pch2
 Filesize:  1.02 KB
 Downloaded:  1224 Time(s)
zeroHertzFM.mp3
 Filename:  zeroHertzFM.mp3
 Filesize:  231.36 KB
 Downloaded:  679 Time(s)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue May 22, 2007 1:21 pm    Post subject: Re: Zero Hertz FM Reply with quote  Mark this post and the followings unread
Yes, if it is not modulated. You need to set zero hertz mode first though.
Change the Oscillator tuning mode to Part (partial) and turn the tune knob all the way left so the display shows 0 Hz.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue May 22, 2007 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
ooh, I should give this a shot.
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue May 22, 2007 7:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gee, thanks a lot guys Smile
the 0Hz osc setting didn't do too much in my patch, but it was the cause of it's beginning. The result patch is epic and fits the layout of the set it reaches in new directions, so maybe it is a sign of sorts ...
And it is only one hour of patching into it too ... Sometimes I feel like "Lt. Data" on Star Trek, The Next Generation". And sometimes as "Bubbles" from the award winning Canadian Comedy show called "Trailer Park Boys".
Thanks for the inspiration Wink
/Dasz
Sotaru
G2 patch files: 5
PostPosted: Thu May 24, 2007 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
ah, taht's the one thing I missed Smile))
Thax!
Marc
