Living Vocoder - re-run 2016(!)
Page 1 of 1 [6 Posts]
rc_hoffmann
PostPosted: Sat Jan 09, 2016 9:44 am    Post subject: Living Vocoder - re-run 2016(!) Reply with quote  Mark this post and the followings unread
Hey,
over the last months a couple of people asked about the Living Vocoder, so I had the idea of doing a limited R&D (re-)run of Jürgen's original 20 band Living Vocoder pcb (100% identical to the original monster pcb released in 2011). As you probably know, Jürgen called it in "debugging state", so this is not a finalized design - my idea is to start another joint beta-phase in order to resume this project, identify and fix any issues or required adjustments, so this is clearly aimed at people both experienced and crazy enough to take this on.
Run will be limited to 20-30 pcbs max (each pcb is appr. 40cm x 30cm! - see photo)!
Price will be in the range of € 100-120 per pcb + shipping (original price was € 300), but please note that this is not a cheap or simple project. More info on the original board: http://jhaible.com/legacy/vocoder/living_vocoder.html
I started an interest check to see if there are about 20-30 people up for this challenge and resonance has been quite strong, so it not only looks like this will happen (ever), but rather that I may be able to order the boards in the next days(!) too much coffee
If you're definitely interested, please shoot an email to vocoder(at)jhaible(dot)com - Thanks!
Random*Source: Serge, Haible & more. Facebook: https://www.facebook.com/randomsource
JanneI
PostPosted: Tue Mar 01, 2016 4:21 pm    Post subject: Re: Living Vocoder - re-run 2016(!) Reply with quote  Mark this post and the followings unread
Group buy for the 1% caps? Anyone?
b-funk
PostPosted: Sun Mar 13, 2016 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
See here:
https://www.muffwiggler.com/forum/topic-155378-0-0.html
JanneI
PostPosted: Sun Mar 13, 2016 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm already there! Thanks anyway! Cheers!
b-funk wrote:
See here:
Techman
PostPosted: Wed Aug 16, 2017 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thought I'd resurrect this thread Very Happy
This is a completed and working vocoder using a board from Random Source.
 Filesize:  1.31 MB
 Viewed:  704 Time(s)
 Filesize:  1.71 MB
 Viewed:  635 Time(s)
 Filesize:  1.37 MB
 Viewed:  623 Time(s)
snorkeldata
PostPosted: Mon Sep 04, 2017 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow!!! That thing looks amazing! Do you have any samples?
